Thanks.And if you short the test probes together what do you get?
Do you know how an ohmmeter like this works?
You won't know whether it is easy to fix until you try. Most likely, if the meter has been treated nicely (nobody tried to measure the resistance of the AC mains, etc.) the problem is likely to turn out to be a poorly working switch contact, a broken component, or poor soldering.
Thanks.Noticed the 'bat' indicator is on. First thing to do is replace the battery.
Thanks.From what it shows, @Martin_R may be right indeed. Ideally, low battery illumination should have a setpoint to just warn the user of an impending need for a battery change without influencing the measurements, but not all meters follow this rule.
If the battery change does not help, the multimeter's PCB may be dirty. I would open it and check for grime and/or residue around the input jacks and other components. Isopropyl Alcohol helps with this. Post good resolution pictures of both sides of the board so we can try to spot anything.
Obviously that, in the end, it may well be a bad switch or a broken component as @DickCappels mentioned.
Thanks.if your lucky ,
you've blown the fuse, I cant see from the photo,
if your unlucky, its the IC under that black blob if plastic,
impossible to repair,
Thanks.Does the other ranges work?
1. A good sign. There is hope that this is still working.Thanks.
1. short the test probes together got 0 at R;
2. I don't know much about how an ohmmeter like this works? need help please;
3. The meter fall in this situation just after a mistake measure;
(Some text removed for clarity)
Thanks.Careful with the springs/contacts/bearings that may fly off.
Thanks.When the rotary switch has problems, that's a really bad sign.
After you replace the battery per @Martin_R measure some resistors and see whether it is working correctly or not.
The measurement circuitry measures the voltage across the probes and applies a constant current to them. The IR drop shows up as voltage across the probes. There may be other means but this is the only means I have noticed on inexpensive meters and several expensive ones too. Knowing this might help you find the problem.
3. Please describe the mistake measure? That might help to figure this out.
Even if you can't get it working again the way you like it, all is not lost, now you have a set of resistors that you can use to make a precision voltage divider for your own projects if you decide to scrap the meter.
My 32 years old Fluke probes (they are marked "Fluke") are looking a little dirty but they work perfectly.You should see the quality of the probes.
by Jake Hertz
by Jake Hertz
by Aaron Carman
by Don Wilcher
