Thank you so much Sir. For your perfect and complete explaination.This Crt is even 3yrs older than me (was a wedding present in my parents wedding ceremony).The two disks inside change resistance with temperature.
Most likely it is used to control current through the degaussing coil. When you first turn on a CRT type TV, for the first 2 seconds current flows through a coil around the CRT that removes the magmatism from the CRT. This device starts out cold with low resistance and a large amount of current flows. In a short time the part gets hot and the resistance increases reducing the current down to almost zero.
In picture #2, what you have is the Thermistor and Varistor.
