Can somebody tell me the value of this resistor?
Ian0
Joined Aug 7, 2020
8,403
I’m reading it from the other end and coming up with 0.5Ω, 1% tolerance and a white band for 1ppm temperature coefficient. That second band looks brown to me.
Lumenosity
Joined Mar 1, 2017
614
I thought resistors were read starting from the end with the biggest gap from the end of the resistor to the first color band?
But I'm not sure.
If that is a five band resistor code then the graphic Android app I use to help identify the color bands doesn't show silver available as a 3rd band?
The app only shows temperature coefficients for 6 band resistors? Perhaps the app I use is deficient?
It's called "Resistor Color Codes"
It all gets so very confusing. But my guess would be that you are correct.
