The switch is illuminated.In this case yes, it won't matter. The PS_ON is held at a logic high through a pull up. Placing it at a Logic Low enables the power supply. Since the switch passes no current to speak of yes, what you have will work. Normally you would not use an AC rated switch for switching DC, however, in this case it doesn't matter. The actual current is a few mA. Not sure what the "lighted" is about unless it is an illuminated switch?
Ron
it is in the switch. It is a Cooper toggle switch. No S/NHow is it illuminated? Are there separate 'lamp' terminals? Should still work if at least one lamp terminal is separate from the contact terminals.
I see something similar said here all of the time. But before becoming a member here I have used AC only toggle switches on DC for over 50 or 60 years. With out ever having one fail.Normally you would not use an AC rated switch for switching DC, however, in this case it doesn't matter.
@shortbus Arcing is an issue with high voltage DC. DC rated switches require specialized designs to reduce the possibility of arcing when the contacts are opened. This typically involves vanes to cut an arc should it occur on opening the switch. Below 50 volts or so shouldn't be an issue.Normally you would not use an AC rated switch for switching DC
Yes, I changed it to the non-dimmer version... Its a neon-bulb in there almost certainly so should work fine for your needs.No dimmer. It is illuminated orange when switched off.
How? PS_on (see post #1) is a TTL compatible signal input.Its a neon-bulb in there almost certainly so should work fine for your needs.
Exactly, so the neon bulb will have no side effects on the use of the switch for the TS' purpose.How? PS_on (see post #1) is a TTL compatible signal input.
That is what most people coming here are asking about, usually in a circuit of around 12VDC, and they're told get one for DC and stay away from an AC switch. I used to argue about it but got too much grief from the "experts". Now that I've been granted the "Expert" status I thought maybe it was time to bring it up again.@shortbus Arcing is an issue with high voltage DC. DC rated switches require specialized designs to reduce the possibility of arcing when the contacts are opened. This typically involves vanes to cut an arc should it occur on opening the switch. Below 50 volts or so shouldn't be an issue.
OK, I confess I clearly wrote it backwards. I always liked this little video. I think we all can agree that in this situation any switch will work. In the case of some illuminated switches the switch just won't illuminate. There is no current to speak of being switched. My apologies for getting things backwards I will consider turning myself in for firing squad in the morning.@shortbus Arcing is an issue with high voltage DC. DC rated switches require specialized designs to reduce the possibility of arcing when the contacts are opened. This typically involves vanes to cut an arc should it occur on opening the switch. Below 50 volts or so shouldn't be an issue.
