First off it was probably not necessary to start a new thread since members are going to be a bit confused between the two. That can be remedied.
As for the power supply, the opamp is actually being operated as an opamp rather than a comparator. The voltage you measured across C1462 was around 15 volts. The trick to the -8volt regulator stage is that Q1468 is acting to control the positive-most end of the 15V secondary transformer winding so that it is exactly 7 volts positive when measured with respect to ground. If you imagine that the load on the -8V output increases then the -8volt output would drop slightly toward 0v. As the -8volts drops the positive input to the opamp begins to go positive. This causes the output of the opamp to go positive which drives the base of transistor Q1466 which in turns drives the base of Q1468 positive. With an increase in the base drive applied to Q1468, it begins to turn on harder. This action pulls the positive end of the transformer secondary supplying the 15V DC down slightly. This results in a restoration of the -8volt output so that the droop due to the increased load is cancelled.
hgmjr
Thanks! I see you merged the threads. You are a super moderator, you can do anything.
Can you suggest a good out of circuit test for that op amp? I can post a list of what I have on hand if needed. But it would help if I could get a range of resistors (for example) and I can post just what I have in the range of those parts.
I think that I would need a virtual ground in the test?
