Yes and that is where the problem or violation of NEC started. The thread starter should have run 12-3 W/Ground. Had he done that he would have no problem having 120 VAC at his irrigation pump site.Got it, Thank you.
So the 12-2 run in TS case is carrying 120 on black (hot), 120 on neutral (white) and then has the bare/green earth ground? I thought 240 needed an extra wire usually a red one. Oh, never mind I asked google I see having a neutral is not required for 240 so it can run the second 120.
Something else I am not real sure of is if irrigation pumps require GFCI? I can't see it required by NEC but I might be missing it plus my last NEC book was the 2008 edition.
Ron
