Thanks, so, the motors (individually) draw from 70mA to max 240mA, the batteries are going to be connected in parallel. I'd like the car to be able to run for at least a hour or two without needing to recharge, I think the batteries should have the juice for that.Welcome to AAC!
Maybe.
- How are the batteries configured? Series? Parallel? Series and parallel?
- How much current does the motor draw?
- How long do you want it to run?
So it has a separate power source?The Arduino needs a 5v supply.
Have a look for "MT3608" on Ebay.
I have not used them, but they sound like a way to go.
Set the output to 5V to run the Arduino. or even 7V is you want to use the Arduino's regulator. That will have a bit more loss, but compared to the motor current, not much.
I have something similar. Ok so, if I connect the batteries is series the voltage would add up so I would have enough to power everything, right?Have a look for "MT3608" on Ebay.
The arduino can be either posted by USB or by connecting 2 cables to certain pins.So it has a separate power source?
