That might be a heavy lift for most MOSFETS. Which one did you have in mind?hi all,
can i generate square wave of (1 - 5 GHz) using mosfet astable circuit ?
regards
Don't know how you could work with something that is only 450 μm or ≈ 18 mils on the long side. Are you going to solder tiny gold wires to it?Hello,
For that frequency range you will need some special fets.
I would take a look at the HEMT fets:
https://en.wikipedia.org/wiki/High-electron-mobility_transistor
The FHX35X is an example.
2 mm ≈ 0.078" is a bit easier to handle, but still requires some skill and dexterity to fabricate.Thats even small lol better watch what package he gets
A square wave at 1 to 5 GHz!? Wow, that is going to take some serious engineering. The result won't be even marginally 'square' if you can't get to at least the 7th harmonic without phase errors and even then it will be a very soft square wave and I cannot see how you might verify the result. The best CRO I have ever used was a LeCroy worth $250k and that had a 1GHz bandwidth and definitely could not have shown a square wave at that frequency even if it could be generated. You'd be able to see the harmonics and their phase on a spectrum analyser and they can go to many 10's of GHz but you'd need to visualise the waveform for yourself because I don't think there is a time domain instrument that could show it to you.hi all,
regards
And was that a square wave output oscillator?I remember a paper that described cross-coupled MOSFETs being used as a regenerative detector, for 2.5 GHz and maybe 5 GHz, so yes it can be done. The oscillator in the paper was on a single integrated circuit. Not sure how well you could do it with discreet components.
The slides you have offered and mentioned in a previous post seem to me to be sine wave oscillators and the mathematical pages seem to be descriptive of sine wave oscillators specifically for communications systems. None of it actually applies to square wave oscillators or so it seems. When you said it could be done, this square wave oscillator at 5GHz, what exactly did you have in mind?It was a subcircuit in a regenerative receiver. The output was, if I recall correctly, data.
Let's please try to stay on topic.
While at it you. mctjo,might pick up some ideas from the attached series of slides.
Frightening numbers, and that is only the fundamental frequency! If you were to settle for a sloppy square wave and therefore only needed to get to the 7th harmonic then your band of interest extends to 35GHz and you need to ensure no appreciable phase differences over the band 5GHz to 35GHz and even then the square wave, not to put to fine a point on it, is going to look pretty awful. Or it would if there were a CRO anywhere on the planet that faithfully could show it to you.This type of thing requires serious engineering skills. You need to manage parasitic capacities, inductances, and other undesirable effects. At 5GHz, a 100pF capacitance is a .3 ohm path from power to ground. A 1nH inductance is a 30 ohm resistance. There is a skin depth of 1 uM through most conductors.
Given the question was for a "square wave oscillator" it is you that is off topic, not anybody else.It was a subcircuit in a regenerative receiver. The output was, if I recall correctly, data.
CRO technology has come a long way since 2004! You can get a CRO now up to 10's of GHz and with plug-ins up to 100's of GHz! There are several Tectronix CRO's now offering this. Who knew! This is fantastic.You can start with DIY pulse generator (mod it to clock with osc) -
http://www.starlino.com/build-a-rea...time-using-an-ultra-fast-sige-comparator.html
https://github.com/podonoghue/Jim_Williams_Pulse_Generator/blob/master/README.md
As far as scope to observe waveform, sampling scopes, like 7000 series Tek with
sampling timebase and vertical amp plugins can take you to 10 Ghz for a few
hundred dollars.
Regards, Dana.
by Jerry Twomey
