Yes, you need to put together a pulse rate counter to count pulses / min. Using a 7 segment display you will need two displays or a single display capable of a heart or pulse rate count. Doing this using discreet components will involve displays, display drivers, and associated counter circuits.can i read the heart rate using this sensor without using MCU ?
int sensor_pin = 0;
int led_pin = 13;
volatile int heart_rate;
volatile int analog_data;
volatile int time_between_beats = 600;
volatile boolean pulse_signal = false;
volatile int beat[10]; //heartbeat values will be sotred in this array
volatile int peak_value = 512;
volatile int trough_value = 512;
volatile int thresh = 525;
volatile int amplitude = 100;
volatile boolean first_heartpulse = true;
volatile boolean second_heartpulse = false;
volatile unsigned long samplecounter = 0; //This counter will tell us the pulse timing
volatile unsigned long lastBeatTime = 0;
void setup()
pinMode(led_pin,OUTPUT);
Serial.begin(9600);
interruptSetup();
void loop()
Serial.print("BPM: ");
Serial.println(heart_rate);
delay(200); // take a break
void interruptSetup()
TCCR2A = 0x02; // This will disable the PWM on pin 3 and 11
OCR2A = 0X7C; // This will set the top of count to 124 for the 500Hz sample rate
TCCR2B = 0x06; // DON'T FORCE COMPARE, 256 PRESCALER
TIMSK2 = 0x02; // This will enable interrupt on match between OCR2A and Timer
sei(); // This will make sure that the global interrupts are enable
ISR(TIMER2_COMPA_vect)
cli();
analog_data = analogRead(sensor_pin);
samplecounter += 2;
int N = samplecounter - lastBeatTime;
if(analog_data < thresh && N > (time_between_beats/5)*3)
if (analog_data < trough_value)
trough_value = analog_data;
if(analog_data > thresh && analog_data > peak_value)
peak_value = analog_data;
if (N > 250)
if ( (analog_data > thresh) && (pulse_signal == false) && (N > (time_between_beats/5)*3) )
pulse_signal = true;
digitalWrite(led_pin,HIGH);
time_between_beats = samplecounter - lastBeatTime;
lastBeatTime = samplecounter;
if(second_heartpulse)
for(int i=0; i<=9; i++)
beat[i] = time_between_beats; //Filling the array with the heart beat values
if(first_heartpulse)
first_heartpulse = false;
second_heartpulse = true;
sei();
return;
word runningTotal = 0;
for(int i=0; i<=8; i++)
beat[i] = beat[i+1];
runningTotal += beat[i];
beat[9] = time_between_beats;
runningTotal += beat[9];
runningTotal /= 10;
heart_rate = 60000/runningTotal;
if (analog_data < thresh && pulse_signal == true)
digitalWrite(led_pin,LOW);
amplitude = peak_value - trough_value;
thresh = amplitude/2 + trough_value;
peak_value = thresh;
trough_value = thresh;
if (N > 2500)
thresh = 512;
peak_value = 512;
trough_value = 512;
sei();
I played with that sensor and an Arduino with a Processing program that had a graph like scope pattern. The placement and pressure of the sensor on your finger or ear lobe determines how good a signal you get. They said if you exert just enough pressure to keep the scope pattern within a certain range, you could trust the BPM.when i place finger i got correct heart rate values for sometime but after a few moments i got high heart rate values(150,200,200>).
so i went to build a circuit which read heart Rate without using MCU.
Thanks for sharing that. All I have here to simulate a signal is an old function generator.I played with that sensor and an Arduino with a Processing program that had a graph like scope pattern. The placement and pressure of the sensor on your finger or ear lobe determines how good a signal you get. They said if you exert just enough pressure to keep the scope pattern within a certain range, you could trust the BPM.
That would likely work well using Audacity which would allow you to record the data to a PC. Pretty cool.You can also have an analog display using an LM2917 tachometer IC. OR a 4 digit counter IC plus a time base. Not trivial but the circuits are widely published. You can also write the program in basic and connect that sensor to your sound input and read the rate on your PC. But that only works if you have a PC.
