Can I connect the RX to TX within the same MCU
bug13
Joined Feb 13, 2012
2,002
Hi guys
It may sound like a silly question, can I connect the TX and RX (of usart) within the same pic (or other MCUs), and if I send one byte out, I can received the same byte?
I have tried it, but it doesn't seem to work in my pic18f24j10. my RX is handle in interrupt.
I have only 0 out, but if I connect my RX to some random signal, I can get some data out.
bug13
Joined Feb 13, 2012
2,002
One thing I need to point out is that I am not using standard baud rate, does it make any different?
21,226
No that should not make a difference. Of course you should make sure you are actually transmitting before you do the loopback.
joeyd999
Joined Jun 6, 2011
5,287
Yes. I do this to 'self-check' the comms on some of my products.
In one case, I have an optical interface. I use a mirror to bounce back a test code...confirming both transmission and reception.
