Can I connect a 14V 2A adapter as an input of a solar charger controller (replace solar panel by a DC adapter?) Will it work properly or not?
Adapter specs:- Self designed 14v 2A bridge rectifier (with 14v regulator ic)
Solar charge controller specs:- Luminous plastic Solar Charge Controller 6amp Model SCC 1206 Range Name (Solar) Solar Charge Controller Dimensions (LBH) 4.06.013.5 CM Charge Controller Rating 6A@12V Max. supported panel power (Wp) 125Wp@12V Input Voltage Range (Voc) 17V-25V
