Hi, I am trying to create a way I can charge my lead acid RV batteries faster. The RV has a 45 amp "converter", which is just a constant voltage 13.8v power supply. With my interior lights on and connected to this power supply, it was charging my discharged 85ah battery at 10a. So it does not charge very quickly.
I was thinking that when I wanted to charge the batteries more quickly (for example when running the gas powered 120v generator for the sole purpose of recharging the batteries) I would parallel in a 20A 13.8v power supply (I happen to have one on the shelf).
Would there be any problems with this? Should I be sure to turn off the 2nd power supply once the battery reaches 13.8v? What if I didn't, would the battery draw any current?
I have a similar question if I were to upgrade the standard constant-voltage 45A converter with a "smart" multistage one. If I did that, I think it would be even more important to turn off the 2nd 13.8v 20A power supply, so the smart charger could do it's work?
Thanks for any help.
Another alternative would be to use a different voltage 2nd power supply. I have several old computer-server power supplies that can deliver 60A at 12v. I might be able to modify them to raise the voltage a little, sometimes to 12.5-13 or so. Would this work better?
