I have an original circuits as follows:
Figure 1 original circuit
Figure 2 12V supply circuit
The circuit in Figure 2 provide 12 V to LM258D amp. Input DIMI_L and DIMI_N are from flyback converter output as follows.
Figure 3 flyback circuit provides power input for the circuit in Figure 2
When I measured the pin 7 output at its original circuit in Figure 1, its output is dc voltage around 10.9V.
After I modified the circuits, which Q1 was replaced with 47K resistor and I put diode between pin 7 and the base of Q3. The output was as follows.
Figure 4 Modified circuit
Here is the modified circuit output, which is not my expectation.
Why does its output perform like this way, not dc voltage output? How does this happen? I don't know if this saturated and the top was cut since this is very big output gain. LM258D Datasheet is attached.
Thank you for your help
