I think I saw a similar thing, I was attempting to use a function generator to get a low voltage pulse into the brain directly, but when the generator was plugged in, even when turned off, it would trigger rapid, inconsistant drum hits. this only happened when the unit was plugged into the wall, sadly this is the only way a function generator is useful lol.If all you do is put a relay or some other type of switch in parallel with the op amp, the input and output of the unpowered op amp wind up in parallel with your drum pad, which is a high impedance device, and can't tolerate much loading. The input and output impedances of an unpowered op amp are unspecified, hard to predict, and hard to simulate accurately, due to the nature of the op amp spice model.
Do you have a datasheet, schematic, or anything else that will tell me what the drum brain's input impedance is? How long is the cable between this preamp circuit and the drum brain? How about between the drum pad and the preamp?
no op-amps were involved. I have a bunch of waveform captures of the drum hits if your interested.
