Buy from these Ali Express/Amazon sellers at your own risk
Ya’akov
Joined Jan 27, 2019
8,975
For anyone that might stumble on this thread because they are searching for high capacity 18650 cells…
At the time of this post, the maximum legitimate capacity for an 18650 cell is 3500mAh.
High quality, reliable cells with this capacity are available from manufacturers like Molicel and Samsung. It is important to consider that capacity is affected by discharge rate and the A (discharge current) rating of a cell must be considered along with the mAh (capacity) rating to determine the best cell for your application.
Increased capacity and discharge current mean increased cost, and you can save some money if you buy cells with reduced discharge current ratings if your focus is battery life and your application doesn’t require maximum current. For example if you are rebuilding a pack for a cordless drill, you might want to choose the more expensive, high current options—but if you are building a pack to run a microcontroller for a long time at low power, you can save money by not choosing something you will never actually use.
Examples of top-end cells are listed in the table below. These are meant to be exemplars only, there are other brands with good reputations—though Molicel and Samsung are common safe bets.
ManufacturerModelStyleCapacity (mAh)Discharge (A)Price (USD)¹
MolicelM35AFT, NP3500107.99
MolicelM35ABT, P3500109.99
Samsung35EFT, NP350087.99
Samsung35EBT, P350089.99
Samsung35EBT, NP350089.99
Samsung30QBT, NP3000157.99
1. Street price from a reputable dealer at the time of this post.
STYLE KEY
FTFlat Top—suitable for building batteries
BTButton Top—for devices with replaceable cells²
PProtected—includes protection circuitry
NPNot Protected—does not include protection circuitry
2. Please note that a button top is no guarantee of protection being present as in the Samsung 35E and 30Q. Such cells should not be used in devices that don’t have their own over-voltage, under-voltage, and over-current protection for the cells—this is a potentially dangerous thing to do and a fire hazard which may not show up until you attempt to charge the cell.
dl324
Joined Mar 30, 2015
16,732
I know they do not have 9900mAh capacity. I used to order such items and used to open disputes with test videos. So I used to get a partial refund and the final cost was too cheap.
I'm actually trying to find some batteries that offer close to the advertised capacity. Now, I send messages before I buy about capacity verification and no-return 100% refunds for batteries that don't actually have much capacity.
The 9900mAh battery I tested had 125mAh capacity. Unfortunately, I didn't know at the time that I needed to test capacity and didn't ask for a refund. I did buy some 18500 1600mAh at the same time that turned out to be accurate (1.59-1.66Ah for the 3 I tested).
The 88800mAh 18650's would have made great 2Ah batteries.
I've been asking for, and getting, 100% no-return refunds. I have no patience or sympathy for sellers who are selling batteries with less than 10% of the advertised capacities. I bought some "real capacity" 2.5Ah 18650's that had about 2Ah of capacity and I'm letting the seller get away with that.
I have some 1.2-2.8Ah 16340's that a member gave me. They test at 5-50mAh. He used them to power a homemade experimenter. I'm looking for some 16340's that would make the experimenter "work". In the meantime, I added a power jack so I can use an adapter for power.
I ended up buying a capacity tester for the last two sets of batteries I purchased because the method I initially used isn't as accurate and I adjusted the discharge current to discharge the batteries in an hour (once I determined the ballpark for the actual capacity). I used one of the cameras from my surveillance system to record battery voltage because it puts the time in the upper left corner. But it breaks up the video every hour; and I didn't want to have to upload videos as evidence that were larger than a few hundred MB.
SamR
Joined Mar 19, 2019
5,021
There was a limit on file size and I kept having to convert images from png to jpeg or gif and in some cases edit the image in order to upload them below their limit. Not sure if an hour long mov file would fit within their limits. Can't find any info online. It just pops up as an error when trying to upload to their report software function.
dl324
Joined Mar 30, 2015
16,732
I think their limit is in the GB range for videos, but I have slow DSL. My surveillance videos are .mp4 with decent compression. An hour is under 300MB.
The problem for me is that I could never upload videos to the AliExpress website. After complaining many times in the midst of a dispute, they said I could upload to YouTube and post the URL. YouTube was much more accommodating of my extremely slow (<1Mpbs) upload speed.
SamR
Joined Mar 19, 2019
5,021
They've mentioned movies to me but I have no desire to do so. Pics are a pain in the ass enough for my lack of patience and I fought them hard about them needing one before I sent the first one to them. FWIW
SamR
Joined Mar 19, 2019
5,021
Flipping through news articles and this little ad popped up...
Now even with the $230 delivery that doesn't sound too bad for a sit-down auto-balancing powered unicycle. See that little "Color: wheelbarrow" near the bottom of the ad? Here is what you are actually buying...
The real deal is...
Caveat Emptor!
dl324
Joined Mar 30, 2015
16,732
I was going to use those 9V lithium replacements but I don't know their self-discharge i.e. would it be OK 3 months from now or would it be dead, boost converter running all the time I think.
Didn't get around to checking the batteries until now; 7 of 8 read 0.0 and the other is around 1.3V. No point in doing a discharge test. All completely discharged in less than 3 months.
dl324
Joined Mar 30, 2015
16,732
I find buying from the whole amazon and Ali express risky. No warranty. Only luck.
You can add eBay to your list.
I'm not looking for the highest quality when I buy from Ali Express. Just something that good enough and will get the job done without having to pay the high prices from "reputable" sources. Like the item in the first post in this thread. Those level shifters from Sparkfun:
You can get them for 10% of that on AliExpress. I got 20 for $5 before buying the ones that weren't packaged correctly.
This PEX tool was $100 at Home Depot:
I got the second on AliExpress when I lost a screw on the "good" one.
Bare semiconductors are a real crap shoot and I resort to testing enough to ease fears of counterfeits that aren't even the part being sold. It isn't feasible for consumers to do comprehensive testing, but DORA is sufficient to know that it wasn't a bait-and-switch transaction.
Even then, I'm hesitant to spend much money on any single transaction.
Ian0
Joined Aug 7, 2020
9,535
I found this welder on Ebay
https://www.ebay.co.uk/itm/33506575...id=TYOgoELnSrG&widget_ver=artemis&media=EMAIL
I'd always fancied having a go at TIG welding, so I asked a few questions as the price was too good to be true:
"Is it supplied with the tungsten electrode?
Where does the gas connect?"
and got this reply:
"Sorry for the late reply,It does not have a tungsten electrode and cannot be connected to gas, otherwise it will explode.
If you have any problems or questions, you could contact us, we would be glad to help you, have a nice day ^-^
Sincerely
Doris"​
A machine that can make argon explode? What can it do with 78% nitrogen? It could make a useful weapon. . .
dl324
Joined Mar 30, 2015
16,732
20 1.6Ah Liter 18500 Li-ion batteries from zenfen. The 10 batteries I tested gave 800-1000mAh. All 10 were tested at least once using a Li-ion battery tester, 3 were tested using a 3 ohm load.
Discharge videos: https: //youtu.be/3KzpKWoXJnE https: //youtu.be/vG25INgwYik
Remove whitespace and visit the page so you can access the chapters to skip around.
Discharge stats from tester:
I purchased 1.5Ah Liter 18500 Li-ion batteries from this seller in the past. Those batteries all delivered around 1.4Ah and were actually the first Li-ion batteries that I bought from AliExpress that provided more than 90% of the stated capacity.
Ya’akov
Joined Jan 27, 2019
8,975
and got this reply:
Sincerely
Doris"
It says it is “TIG” in the specs but as far as I can see it is only a stick welder.
dl324
Joined Mar 30, 2015
16,732
Something to watch out for with some banana plug to alligator test leads from AliExpress. Some use a coated ferrous metal (steel?) instead of copper wire and the crimping sometimes leaves a bit to be desired. They save labor costs by folding the wire back and using the insulation crimp to make contact. Sometimes they don't get the wire under the insulation.
Inexpensive lead on left, right is lead from a Wanptek power supply.
Sometimes the jaws don't align either. I bend the "tooth" on the tip to fix them.
SamR
Joined Mar 19, 2019
5,021
Here's an interesting device on AliX. Capacitor discharge "pen". Unlike what the title says, it is marked for 650VDC. It has tested out at ~70mA discharge rate. LED on when dischargeing and off when charge drops below ~10V. Less than 4USD +tax and shipped free. Nice review here
Would never trust this "pen", too small and too many lil semi's. You are shedding energy as heat.
Along the lines of Mr. Carlson's cap discharger build, I went with 50W resistors for discharging caps in SMPS primary or tube gear or microwave oven caps. The cheap power resistors on AliX are not good for isolation voltage element-case. Aluminum-housed 50W in the most auspicious RX24 series made by villagers in Elbonia are looking good for price- until I found the pic of the sand inside and airgap lol. You don't want an arc to the housing/enclosure. So I bought the real thing for a few dollars more.
I use a piezo buzzer+LED zener also on the main discharge resistor to let me know when the discharging is finished.
dl324
Joined Mar 30, 2015
16,732
Test leads advertised as "copper core". Wire, and clips, are ferrous.
I ordered 28mm and 35mm.
AliExpress has changed their dispute process and you can no longer specify whether you want a refund only, no return. Their decision was full refund with no return.
TIP: The silicon covers are sometimes quite slippery. Wiping them with a paper towel usually helps. Isopropyl alcohol helps with the really slippery ones.
EDIT: A significant number of the crimps are poor. 10% in one package, 40% in another. Haven't opened the other 5 packages yet.
