Eeks!Well let me say I share everyone's frustration. I myself do not want to use this part, but it works faithfully at 185 degrees Celsius which is a requirement of this application (nevermind what datasheet about temp., i assure you it works). With this temp restriction, I only have limited choices.
Lead tin solder starts to melt around 180'C. And every cap, resistor and inductor will be rated for 85'C max apart from some specialty 105'C parts and maybe some MILspec parts at 120'C. Never mind the "zener diodes" you just asked about.
Is this another troll fest?
Yep, ignore the datasheet max temps and ask random internet strangers to improve your circuit and make it work. That's the way to design a product....re 185'C ...(nevermind what datasheet about temp., i assure you it works)...
