Hi, I understand what you are saying and the input is appreciated. The wind turbine is just one application. The faster any PMA spins the more it acts like a electric brake. The problem relates to the internal resistance of the stator. Even if you make the PMA with a low internal resistance and use very large magnets, the problem still exists. Without finding a solution to this problem it is like driving your car with the emergency brake on. Take the wind turbine out of the equation. This problem has to be solved first before anything else can be considered. I only found out about the solution seven months ago, there is still a lot of work to do on the circuit before a micro and feed back circuits can be added.
Problem that still needs to be address:
finding a circuit that will limit the input voltage to below 400 volts
any suggestion are welcome
