Never came up with a 3.3 zener so I've had a 10K pot on U1C from the get-go. Doesn't seem to touchy. It's one of those 15 turn PCB mounts.Did you manage to get R14, the 10k pot wired up to U1C's input and set at about 2.9v to 3.3v?
SP
I looked for that assortment but my local store didn't have it.Did you buy their assortments of 15 2N3906-type PNP and 15 NPN transistors?
One other nice thing about milsurp alternators is that they're all the same! Doesn't matter if it came off a Jeep, a HMMVEE, a 2&1/2 ton, a 5-ton, 7-ton, they're all the same unit.I like military surplus! I'll have to do some poking around here locally ....
I see. Well, "on hand" = "free", which is a hard-to-beat price!What I have on hand tho are standard GM alternators off of my old painter vans. I'll cut the stock bracket up for the adj pulley part and besides that, they're as common as dirt. I could wreck a bunch of them!
LOL! Well, missed decimal places seem to be a pretty common occurance around here!And wow! Did I miss on calcing the potential output or what? I realize it was a decimal error now. 30v times 10 amps is only 300 and here I was thinking 3000? Those smiley things should have one labeled dummy just for me.
Good deal! I'm a bit surprised it's that high, but that's because the resistor is 1.2k instead of 1.1k. That's OK though; we can just compensate with the trimmers.The TL082 is alive, well, and making 5.73v just like the zener. We have achieved Post #29.
Yeah, it kind of helps to have related things together. Less chances of shorting things out, too!Moving on to U1D I'm thinking about ripping it all out and getting some more breadboard practice. With U1D I need the full zener output on different sides of the 339. I'm afraid it'll get looking like a rats nest again. U1C can be on the other side because I gotta get to a pot 1st anyway. If I place U1A and U1D on the same side of the 339 it'll pin out a lot cleaner and be a lot less confusing. I think. LOL!
There ya go. I was hoping you'd figure that out You'll be surprised at how many parts go away because of that mod.Along the lines of freeing up a comparator .....
U1B looks like the candidate. If I reverse the inputs on U1A, and initially I did, it goes up when the battery level drops, but then there's no way I could see to get the hysteresis working. So I used U1B to invert the output of U1A.
But I'm thinking there's some natural hysteresis from the 20A starter motor. Right now I'm operating on a re-chargeable battery pack that will start a car, and that 20A motor is bringing it down a couple of volts. Unless I disconnect or pull the rope on the Briggs the circuit won't shut off. Restoring the depleted battery supply won't do it because it's been hysteresis'd all the way down to 11V by the starter!
Yep, it's going to drop the Vcc line by at least a volt, probably more like several. Starters are very heavy current loads. Automotive starters can be several hundred Amperes.My battery pack may need to be charged but unless we're operating from a regulated power supply I'm thinking that motor is gonna affect the supply voltage. Even with a real battery it should be enough to drop the + input at U1A some amount of millivolts all by itself. That's what's happening on a larger scale now.
I don't know. It took several days just to debit my account. No tracking info. I can write to an e-mail address ......What's the deal with your starter interface for the motor?
OK, good deal. You could use a couple of 100 Ohm resistors in parallel to get 50 Ohms, which is close enough.Found 2N2222's and 2N2907's at Radio Shack so we're sporting those at Q4 and Q5, but I forgot to check my stock and neglected to get a 47 ohm resistor for R17 while I was there. Closed now. So I stuck 100 ohms in at R17 that being the smallest I had on hand and I have NOT powered up ... yet.
Well, the idea is to turn the gate on and off quick, but avoid burning up the transistors. If you switch a MOSFET slowly, it's operating in the linear region (high resistance) and it heats up mighty quickly - and when they're hot, their resistance increases, which makes them even hotter! So, doubling the turn-on time isn't something that we really want to do.Seems like it'd be safe enough tho. Just less current thru Q4 and Q5.
Yep - besides, the IRF510 is mighty low current compared to the IRF9Z34. Check out the spec sheet on it. You can get one from Mouser.com, Alldatasheet.com, and a bunch of other places. View what's printed on the Radio Shack package with a jaundiced eye; they're frequently wrong.I also stumbled across an IRF510 and for $2 it's mine now! But I just noticed it's an N channel and I believe the IRF9Z's are P channel. I don't know what that means but I'm pretty sure the 510 won't work because of it.
That's vaguely right. But, MOSFETS are a whole 'nother critter than BJT's (transistors). The gate is more like a noose; when it's at 0v relative to the source, the current is choked off. When it's 10v relative to the source (-10v for P-channel), it's wide open, and them electrons just stampede right on through. Where ya get in trouble is when the Vgs is just a few volts; then it's like the I-10 freeway at 4pm. The gate has capacitance, which has to be charged and discharged. It doesn't really draw any current, unlike a transistor. A transistor has hFE, which is current gain. You put some current in the base, and you control more current at the collector; the base current times the hFE. The tough part is that the hFE changes depending upon how much current is flowing through the collector, and temperature has a BIG effect on hFE as well.Speaking of which, I'm assuming the gate is equivalent to the base in transistor terms. Source is collector? Drain = emitter?
Well, that's another thing. You could try it. Quite frankly, I'm not sure how much current it's going to take to power the rotor to get the output charge current you need. I've never bothered to check that. You get to be the guinea pig.I'm also wondering about simulating the field with a large wattage resistor. 15 watts?
LOL! I am a pig. At least the wife says so .....You get to be the guinea pig.
Well, I was thinking more like have an alternator on either side of the Briggs flywheel, with two pulleys on the Briggs. That way you would counterbalance the tension on the Briggs crank bearings, possibly reducing the bearing friction.I thought about running 2 of the 65's. It'd look like a multi-headed monster! LOL! If I used an "L" configuration only one would have to be adjustable for belt tension ....
IKNOWDAT! It's just that some have diode trios, and some don't. It appears that those which do have diode trios, do not have the internal capacitors. Having a decent-sized capacitor at the alternator is a good idea; it will cut down on noise. I also think that the newer alternators that have the cap inside them have switching regulators. From what I read on the 130 Amp alternator, it has a 400Hz PWM circuit.The regulator and brush holders are separate pieces BTW.
Ahh, let's see.It'd be very easy to put some stand offs where the reg used to be and wire direct thru the brushes to the rotor windings. The rotor winding is 3 ohms so I wouldn't think we'd ever see 4 amps per unit. Still well within the IRF9z's capability.
Hmm, interesting. So, if you ran the Briggs at around 3,000 RPM with a 2:1 pulley ratio, the alternators zingin' & singin' at 6,000 RPM, you'd have plenty of power reserve and the alternators would be getting a good bit of cooling air pumped through 'em.Some results from digging. 8SC3014U seems to be a military designation for a 24v 100 amp alternator but Leece-Neville calls it a 110-298. Interesting too were the graphs I saw where the amp output leveled off at about 6000 rpm.
