Looking for a circuit to monitor the state of up to 2 fuses and energize a relay if either one of the fuses blows but not energize the relay if only one fuse is installed in the fuse holder and the other position is not filled (unused).
Would also like a failure led for each fuse position.
Trickier part is the supply voltage is - or + 24vdc. I need the circuit to function with either polarity and not have 1 for plus and 1 for negative.
Thanks in advance for any help you provide.
