What SGT said...and it still doesn't have any way to differentiate between a blown fuse and an empty fuse holder.yes, requirements are the same.....Why do you say that doesn't work?
Ken
You're welcome.Thanks for all your help Sgt.
Circuitmaker Student. It is an old program that is no longer supported by it's authors. It is limited to 50 components in a simulation, and you cannot add components to the library.Can I ask what program you did that schematic/simulation in?
Yeah, Ken - but it would be tough to determine an empty fuse holder vs blown fuse unless the fuse holder had some kind of switch....and it still doesn't have any way to differentiate between a blown fuse and an empty fuse holder.
I agree, but the OP said their spec's haven't changed, and as you say (and I said early on) you would need a special holder. Otherwise, your original bridge/LED circuit would work. Maybe they can tell us why an empty fuse holder is to be ignored.Yeah, Ken - but it would be tough to determine an empty fuse holder vs blown fuse unless the fuse holder had some kind of switch.
In my opinion, just having an indication that there was no connection through the fuse holder would be adequate; one way or the other, the load won't get powered until someone replaces/inserts a fuse.
I realize that all I'm doing is indicating the blown fuse by turning on an LED; there are no provisions to energize a relay....monitor the state of up to 2 fuses and energize a relay if either one of the fuses blows but not energize the relay if only one fuse is installed in the fuse holder and the other position is not filled (unused)...
(1) Your LED polarity is wrong.If I measure voltage on each transistor with a blown/missing fuse (one lead on base and one lead on emitter the voltage is approx .7vdc) What am I missing?
This was not exactly my point. Some of the schematics had at least a resistor to limit current but at least one had no such limitation if the sensor circuit itself failed. From a safety point of view, the sensor circuit should have its own fuse. This is to insure that excessive current will not find a path through the defective device, or the sensor components direct to Gnd.mcgyvr,
CDRIVE has a very good point. The fuses are there to open a circuit "completely" under fault conditions. The question is: what's the risk if a small current...maybe 5mA...continues into the faulty load.
Ken
