bk precision 3010 function generator low output volts?
pastinsain
Joined Aug 25, 2012
163
just got this function generator and dosn't seem to function.
It only puts out .5v at max on any setting. It should be 10v on dc output.
its one of those ebay deals seller said works perfect
I tested with fluke 25 multimeter and tek 475a for volts and function .
volt range id .01 to .5 v
any ideas for the low volts output?
dataman19
Joined Dec 26, 2009
135
First: have you recapped the generator ) electrolytics get bad with age ad sitting a long time dormant will also age them significantly).
Dave
Phoenix, AZ
pastinsain
Joined Aug 25, 2012
163
Recapping the power caps? Im sure they need to be.
That would be one or two power caps probably.
there is no telling what else has drifted in value. I paid $80 for it and may just return the ebay item. If I had paid only $20 or so I would fix it. however, Its was described as fully functional working condition and that makes me want to return it even more!
pastinsain
Joined Aug 25, 2012
163
But they both only output .5vdc max
They manual says 10vdc on the TTL when used as a DC power supply.
All buttons out mode
PatM
Joined Dec 31, 2010
86
With the DC offset in the 12:00 position, the TTL out reads 2V dc and about 1.9 AC.
In the 600 ohm out, it reads about 9.7 VAC.
I can't find my manual, but those are the observed readings.
Dodgydave
Joined Jun 22, 2012
11,302
i have the circuit diagram for this model BK precision 3010
if you email me on <SNIP> i can send it to you in pdf form
as it wont upload on this site.
