You should change the conception of the circuit, because you want to using +5V to be the power source, so
+5V → xxΩ → 2VLED → 2VLED → Vce(0.2V) → GND
You can calculate the value of resistor.
OK, i was just checking and testing the whole experiment after taht i have some result it was good to study..
i have used series combination of two red led which has Vf of 2V and combined several parallel led with them near about 15+15=30 it was working fine as i increases the led the currents increasing very slowly in very few mA near 2mA. and the voltage across 110ohm was 1V, after that i have added total 12 parallel 110ohm one by one the voltage become across R was 0.78V and current also increases and there was not so much power diss across R which was achievement then earlier....
so, my red led project is over and i am thinking about white LED which has Vf of ~3V so, how to combine with 5V 2V across resistance so, should i use 9V for it making 3 or 2 in series??/
Don't drive the LEDs from the 5V regulator. Use the 9V source directly.
