I use this one and like it a lot. https://www.amazon.com/gp/product/B00068IJPO
For thru-hole, the diameter may be smaller than it needs to be and you could go larger, but that small diameter comes in handy for other things.
And for grins and giggles to give a bit of diversity I use this one...
They are all good and Kester is a very well-respected old brand with many options in their product line. Find one that you like that works well for you. But I would choose a Kester lead product.
I certainly concur with the recommendation of Kester products, and for that matter Alpha as well.
My general advice is:
63Sn/37Pb alloy
.031“ diameter for general PCB use
No clean flux core
Kester or Alpha brand
Absolutely avoid RoHS lead-free solder unless you are forced to use it
Avoid activated flux core because you will have to clean the PCB to avoid corrosion
Don’t buy “cheap” solder, it isn‘t even worth what you pay for it
Additionally, I would suggest you get a solder dispenser stand. Even a very good one from someone like Hakko is not very expensive but it will make life much easier.
Get a flux pen, the Kester 951 no-clean pen would be my choice. It can go a very long way to making reluctant connections, and it won’t get burned off the way the core’s flux will if the solder is left on the tip too long. While “carrying” solder on the iron is not ideal, sometimes if you apply flux to the parts first, putting some solder on the tip and letting it get fully hot before applying it to the joint can wet things that are otherwise very reluctant to take the solder.
I also think the suggestion of having some activated flux on hand is a good one. If you need it, it can be a project saver. I would get the Kester 186 pen which they suggest is equivalent in fluxing action to RA fluxes without corrosive residue.
These pens don’t look cheap but in fact they last a very long time because they apply a thin film of flux which is very effective and efficient.
One more thing is temperature. The manufacturers‘ data sheet will have process information including recommended temperature. I would stick to that. If the solder doesn’t seem to work well at that temperature, it means your iron isn’t maintaining (or reaching) it. Proper calibration with a tip thermometer (knock-offs of the Hakko 191 are cheap and cheerful) and empirical testing to keep the temperature down to the minimum working number taking into account the heater’s capacity and tip’s thermal mass.
The best solder in my assorted stock, as far as for quickly wetting and sticking, came from Radio Shack many years ago. It has a core of more active flux than other flux core solders I have used.
Certainly the Kester brand catalog will have an equivalent.
I'm wondering now how I decided on 60/40 instead of 63/37. I know I researched it at the time and convinced myself it was the way to go. Maybe it was cheaper that day? But 63/37 is the eutectic blend and has the lowest (and sharpest) melting point. It makes good sense to use it as the default solder.
Maybe they were calculating it with a slide-rule back then and rounding it off? It was Richard Feynman who suggested teaching introductory physics using 10m/s^2 instead of 9.8 to help students understand the concepts without tripping over the math.
YES!!!
I recently purchase some rolls of 60/40 solder on Ebay (so probably deserve it).
It turns out they sent me Lead Free!!!
Not happy and they only refunded a small part of the purchase price. Anyone want some Lead free solder???
I had some 'old' solder lying around that I once used for a PCB board I was building up. Big mistake! Even after trying to clean the board multiple times with Isopropyl alcohol, the board would not work properly. It had stray resistances between parts causing all kinds of problems. I now us no clean, 63/37. The board cleans up very nice and pretty and no issues.
