I have 16 1.5V batteries, and I need 12V with as much electrical current as possible. What would be the best configuration? Thanks!
What is the load and how long does it need battery voltage to be 12V?I need 12V with as much electrical current as possible.
How much current do you need? How sensitive is the load to voltage variation?1.5V AA Duracell Alkaline batteries
Regular household appliances, around here anyway, run on 120V AC.The load is a regular household appliance.
You're not going to be able to use AA batteries to run most appliances.The load is a regular household appliance.
Connect + to + and - to -.How can I connect 2 batteries in parallel?
What size are the batteries? 5W would require 3.3 amps.if a have 2 batteries Duracell 1.5V to power a 5W device.
What makes you think that increasing current capacity from the battery would make the device perform differently? All it will do is increase run time.My objective is to increase the current.
You need to be specific. This is like asking someone on an internet forum what kind of car you should get and then when they ask you what you are going to use it for not giving enough information to even distinguish between going to the convenience store to get a gallon of milk and towing your five ton travel trailer across the country.Maybe a small TV.
by Jerry Twomey
