A metallic bar is placed in front of the solenoid, on the axis of the solenoid but not inside it. When a DC current is passed through the solenoid, the bar will be strongly attracted, weakly attracted or weakly repelled if it is ferromagnetic, paramagnetic or diamagnetic respectively. What happens AC current flows through the solenoid? We have to consider induced currents in the bar as well, because of changing flux.
My question is: suppose the bar is made of iron and it is an AC solenoid. Will the bar be attracted or repelled or will it oscillate? I am confused about the fact that induced current will always oppose the change in flux and thus the bar will be repelled. On the other hand, the magnetization created within the bar should attract it to the solenoid. Further, in the second case, does the hysteresis loop play a role?
Thanks in advance for your detailed replies.
