If you apply a square wave voltage to a coil, the current waveform will be of a different shape.ok, I'll read up on inductors I guess. Not sure why I can't have a 22V potential difference moving at 1 amp. The square wave is high? Any clarification would be welcome.
Depending on the relationship between the inductance and resistance of the coil, and the operating frequency, the current waveform will be somewhere between a triangular wave (inductance/resistance >> half period) and an approximate square wave with softened edges (half period >> inductance/resistance).
The only way that both current and voltage can be (near) square waves at the same time is if the coil has negligible inductance compared to its resistance, so that the coil is functionally a resistor - in your case a 22Ω resistor.
