strantor, your design will work if you just put a pull-down resistor on the base of the pnp and the nightwatchman is very close to the supply voltage when its output is high. If the output isn't all that high, we can use a zener for a "spacer". 560 ohms to get 20 ma drive on the base and 200 ma on the collector (as a saturated switch).
Ifly: Nothing is set in stone..yet. Go get a couple of 5 pin car relays (single pole, double throw). Hint: There are dead cars in the junk yard. If not convenient, pay retail.
For the limit switches, 3 pin microswitches (single pole, double throw) are pretty common and cover what we need. Right strantor?
Edit: Alarm! If you tried to measure continuity of the nightwatchman (from output to ground) when it was in the "night" condition, it applied 12 volts to your ohm meter. Check for a blown fuse.
