Ati video card x1650 st up on Xubuntu 18.04 2 Monitors with DVI
Discussion in 'Computing and Networks' started by frank55, Jan 10, 2019.
  1. frank55
    Thread Starter Active Member
    Dec 6, 2013
    301
    10
    Hi guys i installed an ATI video card X1650 with 2 DVI outputs with 2 monitors and set displays 1 is 19'' the other is 20'' both 16-9 wide screen,i st resolution to 1280-1024, the 19'' monitor has the right screen the other not so much it falls short,check screen pic attach. also it's on Xubuntu 18.04 Distro.Is there anything i can do,thanks
  2. nsaspook
    Aug 27, 2009
    5,165
    5,686
    Really bad pictures.
    What type of dual display do you want, independent monitors and screen managers or shared surfaces? Lets see your xorg.conf file if you have one.
    With dual displays I normally run independent monitors and screen managers as it isolates user interaction with one keyboard and mouse. I use Nvidia on most system but the X setup of display resolution and monitors should be similar.
    My xorg.conf for dual monitor. Note the sections for Monitor, Device and Screen.
    Code (Text):
    1.
    2. # nvidia-settings: X configuration file generated by nvidia-settings
    3. # nvidia-settings: version 384.111 (build-user@build-machine) Thu Jan 11 19:52:21 UTC 2018
    4.
    5.
    6. Section "ServerLayout"
    7.
    8. # Removed Option "Xinerama" "0"
    9. # Removed Option "Xinerama" "1"
    10. Identifier "Layout0"
    11. Screen 0 "Screen0" 0 0
    12. Screen 1 "Screen1" 1680 0
    13. InputDevice "Keyboard0" "CoreKeyboard"
    14. InputDevice "Mouse0" "CorePointer"
    15. Option "Xinerama" "0"
    16. EndSection
    17.
    18. Section "Files"
    19. EndSection
    20.
    21. Section "InputDevice"
    22.
    23. # generated from default
    24. Identifier "Mouse0"
    25. Driver "mouse"
    26. Option "Protocol" "auto"
    27. Option "Device" "/dev/psaux"
    28. Option "Emulate3Buttons" "no"
    29. Option "ZAxisMapping" "4 5"
    30. EndSection
    31.
    32. Section "InputDevice"
    33.
    34. # generated from default
    35. Identifier "Keyboard0"
    36. Driver "kbd"
    37. EndSection
    38.
    39. Section "Monitor"
    40.
    41. # HorizSync source: edid, VertRefresh source: edid
    42. Identifier "Monitor0"
    43. VendorName "Unknown"
    44. ModelName "Envision G2219w1"
    45. HorizSync 30.0 - 83.0
    46. VertRefresh 50.0 - 76.0
    47. Option "DPMS"
    48. EndSection
    49.
    50. Section "Monitor"
    51.
    52. # HorizSync source: edid, VertRefresh source: edid
    53. Identifier "Monitor1"
    54. VendorName "Unknown"
    55. ModelName "Acer AL1916W"
    56. HorizSync 30.0 - 82.0
    57. VertRefresh 56.0 - 76.0
    58. Option "DPMS"
    59. EndSection
    60.
    61. Section "Device"
    62. Identifier "Device0"
    63. Driver "nvidia"
    64. VendorName "NVIDIA Corporation"
    65. BoardName "GeForce GT 710"
    66. BusID "PCI:11:0:0"
    67. Screen 0
    68. EndSection
    69.
    70. Section "Device"
    71. Identifier "Device1"
    72. Driver "nvidia"
    73. VendorName "NVIDIA Corporation"
    74. BoardName "GeForce GT 710"
    75. BusID "PCI:11:0:0"
    76. Screen 1
    77. EndSection
    78.
    79. Section "Screen"
    80. Identifier "Screen0"
    81. Device "Device0"
    82. Monitor "Monitor0"
    83. DefaultDepth 24
    84. Option "Stereo" "0"
    85. Option "metamodes" "DVI-D-0: nvidia-auto-select +0+0"
    86. Option "SLI" "Off"
    87. Option "MultiGPU" "Off"
    88. Option "BaseMosaic" "off"
    89. SubSection "Display"
    90. Depth 24
    91. EndSubSection
    92. EndSection
    93.
    94. Section "Screen"
    95.
    96. # Removed Option "metamodes" "HDMI-0: nvidia-auto-select +0+0 {reflection=Y}"
    97. Identifier "Screen1"
    98. Device "Device1"
    99. Monitor "Monitor1"
    100. DefaultDepth 24
    101. Option "Stereo" "0"
    102. Option "nvidiaXineramaInfoOrder" "DFP-1"
    103. Option "metamodes" "HDMI-0: nvidia-auto-select +0+0"
    104. Option "SLI" "Off"
    105. Option "MultiGPU" "Off"
    106. Option "BaseMosaic" "off"
    107. SubSection "Display"
    108. Depth 24
    109. EndSubSection
    110. EndSection
    111.
    On the web on one while watching a recorded OTA tv show on the other.
  3. frank55
    Dec 6, 2013
    301
    10
    Thanks nsaspook this is ATI video card and OPS Xubuntu 18,04,also i wanted it to the same screen
  4. nsaspook
    Aug 27, 2009
    5,165
    5,686
  5. shteii01
    Feb 19, 2010
    4,462
    706
    The monitors usually have some kind of auto adjust feature. Try it.
  6. frank55
    Dec 6, 2013
    301
    10
    Thanks guys ; The max resolution of the Top 20'' Display that gets the right full screen
    1680-1050 and the bottom 19'' screen max resolution 1600-900 this one is the one that cuts on the sides,if i change to any other lower resolution on to screen it does good but the bottom one will not have the right centered screen.
    Is there ATI catalytic control for Ubuntu 1804?
    https://postimg.cc/GTBxPWks/0a231b3a
  7. nsaspook
    Aug 27, 2009
    5,165
    5,686
    Nvidia-setting utility. Sadly, these types of problems are why I never use ATI video cards other than embedded server video setups.
    Sorry, no idea if there is a similar utility for ATI but you should be able to manually edit the X configuration file to set a resolution for each screen. It would be nice if you posted it so we could take a look.
    https://askubuntu.com/questions/74808/how-do-i-force-a-resolution-of-1024x768
    https://www.phoronix.com/scan.php?page=news_item&px=AMDGPU-PRO-18.30
    https://www.amd.com/en/support/kb/release-notes/rn-prorad-lin-18-20
    https://linuxconfig.org/how-to-inst...n-drivers-on-ubuntu-18-04-bionic-beaver-linux
  8. frank55
    Dec 6, 2013
    301
    10
    Thanks my friend; i was using Nvidia integrated card before but had no good support drivers for my card in xubuntu 18.04 and was screwing up graffics although in xubuntu 16.04 it had support and worked ok,i had to install my external ATI cards that i had hanging around and i have 2 of them,i did not want to go back to Xubuntu 14.04 ,i remember that back in Ubuntu 14.04 there was support for ATI catalytic drivers that included ATI catalytic control to, but these modern darn days old stuff is ditched,even by LINUX ,but in the end they think that i throw my old hardware in the trash and go buy new, they will not succeed ,not with me.
    frank@frank-ET1331G:~$ inxi -F
    System: Host: frank-ET1331G Kernel: 4.15.0-43-generic x86_64 bits: 64
    Desktop: Xfce 4.12.3 Distro: Ubuntu 18.04.1 LTS
    Machine: Device: desktop System: eMachines product: ET1331G serial: N/A
    Mobo: eMachines model: MCP61PM-GM serial: N/A
    BIOS: AMI v: P01-A2 date: 12/10/2009
    CPU: Dual core AMD Athlon II X2 250u (-MCP-) cache: 2048 KB
    clock speeds: max: 1600 MHz 1: 1400 MHz 2: 800 MHz
    Graphics: Card: Advanced Micro Devices [AMD/ATI] RV535 [Radeon X1650 PRO]
    Display Server: x11 (X.Org 1.19.6 )
    drivers: ati,radeon (unloaded: modesetting,fbdev,vesa)
    Resolution: 1280x1024@75.02hz, 1280x1024@75.02hz
    OpenGL: renderer: ATI RV530
    version: 2.1 Mesa 19.0.0-devel (git-8847370 2019-01-05 bionic-oibaf-ppa)
    Audio: Card-1 NVIDIA MCP61 High Def. Audio driver: snd_hda_intel
    Card-2 C-Media driver: USB Audio
    Sound: Advanced Linux Sound Architecture v: k4.15.0-43-generic
    Network: Card: NVIDIA MCP61 Ethernet driver: forcedeth
    IF: enp0s7 state: up speed: 100 Mbps duplex: full
    mac: 44:87:fc:70:cc:84
    Drives: HDD Total Size: 250.1GB (4.7% used)
    ID-1: /dev/sda model: ST3250318AS size: 250.1GB
    Partition: ID-1: / size: 229G used: 11G (6%) fs: ext4 dev: /dev/sda1
    RAID: No RAID devices: /proc/mdstat, md_mod kernel module present
    Sensors: System Temperatures: cpu: 18.4C mobo: N/A
    Fan Speeds (in rpm): cpu: N/A
    Info: Processes: 179 Uptime: 27 min Memory: 652.1/3945.2MB
    Client: Shell (bash) inxi: 2.3.56
  9. nsaspook
    Aug 27, 2009
    5,165
    5,686
    Finally some real information I can use.
    You're using the open source ATI driver in 1280x1024 mode. These old cards need manual configuration and are too old for the Linux ATI catalytic driver. Your best bet is to get lucky and find a working /etc/X11/ files.
    https://www.x.org/releases/current/doc/man/man4/radeon.4.xhtml
    Can you post the /var/log/Xorg.0.log (the numbering system might be different) file.
    Some of mine for a Nvidia card:
    Code (Text):
    1.
    2. [ 158.458]
    3. X.Org X Server 1.20.3
    4. X Protocol Version 11, Revision 0
    5. [ 158.458] Build Operating System: Linux 4.9.0-8-amd64 x86_64 Debian
    6. [ 158.458] Current Operating System: Linux nmusic 4.19.0-1-amd64 #1 SMP Debian 4.19.9-1 (2018-12-16) x86_64
    7. [ 158.458] Kernel command line: BOOT_IMAGE=vmlinuz.pxe rw initrd=initrd.pxe root=/dev/nfs ip=dhcp nfsroot=10.1.1.2:/srv/nfs1
    8. [ 158.458] Build Date: 25 October 2018 06:15:23PM
    9. [ 158.458] xorg-server 2:1.20.3-1 (https://www.debian.org/support)
    10. [ 158.458] Current version of pixman: 0.36.0
    11. [ 158.458] Before reporting problems, check http://wiki.x.org
    12. to make sure that you have the latest version.
    13. [ 158.458] Markers: (--) probed, (**) from config file, (==) default setting,
    14. (++) from command line, (!!) notice, (II) informational,
    15. (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
    16. [ 158.458] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Dec 20 18:17:09 2018
    17. [ 158.470] (==) Using config file: "/etc/X11/xorg.conf"
    18. [ 158.470] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
    19. [ 158.494] (==) ServerLayout "Layout0"
    20. [ 158.494] (**) |-->Screen "Screen0" (0)
    21. [ 158.494] (**) | |-->Monitor "Monitor0"
    22. [ 158.494] (**) | |-->Device "Device0"
    23. [ 158.494] (**) |-->Screen "Screen1" (1)
    24. [ 158.494] (**) | |-->Monitor "Monitor1"
    25. [ 158.495] (**) | |-->Device "Device1"
    26. [ 158.495] (**) |-->Input Device "Keyboard0"
    27. [ 158.495] (**) |-->Input Device "Mouse0"
    28. [ 158.495] (**) Option "Xinerama" "0"
    29. [ 158.495] (==) Automatically adding devices
    30. [ 158.495] (==) Automatically enabling devices
    31. [ 158.495] (==) Automatically adding GPU devices
    32. [ 158.495] (==) Max clients allowed: 256, resource mask: 0x1fffff
    33. [ 158.512] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
    34. [ 158.512] Entry deleted from font path.
    35. [ 158.523] (==) FontPath set to:
    36. /usr/share/fonts/X11/misc,
    37. /usr/share/fonts/X11/100dpi/:unscaled,
    38. /usr/share/fonts/X11/75dpi/:unscaled,
    39. /usr/share/fonts/X11/Type1,
    40. /usr/share/fonts/X11/100dpi,
    41. /usr/share/fonts/X11/75dpi,
    42. built-ins
    43. [ 158.523] (==) ModulePath set to "/usr/lib/xorg/modules"
    44. [ 158.523] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
    45. [ 158.523] (WW) Disabling Keyboard0
    46. [ 158.523] (WW) Disabling Mouse0
    47. [ 158.523] (II) Loader magic: 0x55600a66ae20
    48. [ 158.523] (II) Module ABI versions:
    49. [ 158.523] X.Org ANSI C Emulation: 0.4
    50. [ 158.523] X.Org Video Driver: 24.0
    51. [ 158.523] X.Org XInput driver : 24.1
    52. [ 158.523] X.Org Server Extension : 10.0
    53. [ 158.523] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory)
    54. [ 158.523] (++) using VT number 7
    55.
    56. [ 158.523] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
    57. [ 158.524] (II) xfree86: Adding drm device (/dev/dri/card0)
    58. [ 158.539] (--) PCI:*(11@0:0:0) 10de:128b:196e:118b rev 161, Mem @ 0xfc000000/16777216, 0xd8000000/134217728, 0xd6000000/33554432, I/O @ 0x00004000/128, BIOS @ 0x????????/131072
    59. [ 158.539] (II) LoadModule: "glx"
    60. [ 158.561] (II) Loading /usr/lib/xorg/modules/linux/libglx.so
    61. [ 159.008] (II) Module glx: vendor="NVIDIA Corporation"
    62. [ 159.008] compiled for 4.0.2, module version = 1.0.0
    63. [ 159.008] Module class: X.Org Server Extension
    64. [ 159.008] (II) NVIDIA GLX Module 390.87 Tue Aug 21 16:10:56 PDT 2018
    65. [ 159.008] (II) LoadModule: "nvidia"
    66. [ 159.009] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
    67. [ 159.095] (II) Module nvidia: vendor="NVIDIA Corporation"
    68. [ 159.095] compiled for 4.0.2, module version = 1.0.0
    69. [ 159.095] Module class: X.Org Video Driver
    70. [ 159.095] (II) NVIDIA dlloader X Driver 390.87 Tue Aug 21 15:44:49 PDT 2018
    71. [ 159.095] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
    72. [ 159.095] (WW) xf86OpenConsole: setpgid failed: Operation not permitted
    73. [ 159.095] (WW) xf86OpenConsole: setsid failed: Operation not permitted
    74. [ 159.098] (II) Loading sub module "fb"
    75. [ 159.098] (II) LoadModule: "fb"
    76. [ 159.099] (II) Loading /usr/lib/xorg/modules/libfb.so
    77. [ 159.112] (II) Module fb: vendor="X.Org Foundation"
    78. [ 159.112] compiled for 1.20.3, module version = 1.0.0
    79. [ 159.112] ABI class: X.Org ANSI C Emulation, version 0.4
    80. [ 159.112] (II) Loading sub module "wfb"
    81. [ 159.112] (II) LoadModule: "wfb"
    82. [ 159.112] (II) Loading /usr/lib/xorg/modules/libwfb.so
    83. [ 159.119] (II) Module wfb: vendor="X.Org Foundation"
    84. [ 159.119] compiled for 1.20.3, module version = 1.0.0
    85. [ 159.119] ABI class: X.Org ANSI C Emulation, version 0.4
    86. [ 159.119] (II) Loading sub module "ramdac"
    87. [ 159.119] (II) LoadModule: "ramdac"
    88. [ 159.119] (II) Module "ramdac" already built-in
    89. [ 159.120] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
    90. [ 159.120] (==) NVIDIA(0): RGB weight 888
    91. [ 159.120] (==) NVIDIA(0): Default visual is TrueColor
    92. [ 159.120] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
    93. [ 159.120] (**) NVIDIA(0): Option "Stereo" "0"
    94. [ 159.120] (**) NVIDIA(0): Option "SLI" "Off"
    95. [ 159.120] (**) NVIDIA(0): Option "MultiGPU" "Off"
    96. [ 159.120] (**) NVIDIA(0): Option "BaseMosaic" "off"
    97. [ 159.120] (**) NVIDIA(0): Stereo disabled by request
    98. [ 159.120] (**) NVIDIA(0): NVIDIA SLI disabled.
    99. [ 159.120] (**) NVIDIA(0): NVIDIA Multi-GPU disabled.
    100. [ 159.120] (**) NVIDIA(0): Option "MetaModes" "DVI-D-0: nvidia-auto-select +0+0"
    101. [ 159.120] (**) NVIDIA(1): Option "MetaModes" "HDMI-0: nvidia-auto-select +0+0"
    102. [ 159.120] (**) NVIDIA(0): Enabling 2D acceleration
    103. [ 160.427] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:11:0:0
    104. [[COLOR=#ff0000] 160.427] (--) NVIDIA(0): CRT-0
    105. [ 160.427] (--) NVIDIA(0): DFP-0 (boot)
    106. [ 160.427] (--) NVIDIA(0): DFP-1
    107. [ 160.497] (II) NVIDIA(0): NVIDIA GPU GeForce GT 710 (GK208) at PCI:11:0:0 (GPU-0)
    108. [ 160.497] (--) NVIDIA(0): Memory: 2097152 kBytes
    109. [ 160.497] (--) NVIDIA(0): VideoBIOS: 80.28.a6.00.15
    110. [ 160.497] (II) NVIDIA(0): Detected PCI Express Link width: 8X
    111. [ 160.499] (--) NVIDIA(GPU-0): CRT-0: disconnected
    112. [ 160.499] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
    113. [ 160.499] (--) NVIDIA(GPU-0):
    114. [ 160.524] (--) NVIDIA(GPU-0): Envision G2219w1 (DFP-0): connected
    115. [ 160.524] (--) NVIDIA(GPU-0): Envision G2219w1 (DFP-0): Internal TMDS
    116. [ 160.524] (--) NVIDIA(GPU-0): Envision G2219w1 (DFP-0): 330.0 MHz maximum pixel clock
    117. [ 160.524] (--) NVIDIA(GPU-0):
    118. [ 160.547] (--) NVIDIA(GPU-0): Acer AL1916W (DFP-1): connected
    119. [ 160.547] (--) NVIDIA(GPU-0): Acer AL1916W (DFP-1): Internal TMDS
    120. [ 160.547] (--) NVIDIA(GPU-0): Acer AL1916W (DFP-1): 165.0 MHz maximum pixel clock
    121. [ 160.547] (--) NVIDIA(GPU-0):
    122. [ 160.599] (II) NVIDIA(0): Validated MetaModes:
    123. [ 160.599] (II) NVIDIA(0): "DVI-D-0:nvidia-auto-select+0+0"
    124. [ 160.599] (II) NVIDIA(0): Virtual screen size determined to be 1680 x 1050
    125. [ 160.676] (--) NVIDIA(0): DPI set to (90, 91); computed from "UseEdidDpi" X config
    126. [ 160.676] (--) NVIDIA(0): option
    127. [ 160.676] (**) NVIDIA(1): Depth 24, (--) framebuffer bpp 32
    128. [ 160.676] (==) NVIDIA(1): RGB weight 888
    129. [ 160.676] (==) NVIDIA(1): Default visual is TrueColor
    130. [ 160.676] (==) NVIDIA(1): Using gamma correction (1.0, 1.0, 1.0)
    131. [ 160.676] (**) NVIDIA(1): Option "Stereo" "0"
    132. [ 160.676] (**) NVIDIA(1): Option "nvidiaXineramaInfoOrder" "DFP-1"
    133. [ 160.676] (**) NVIDIA(1): Option "SLI" "Off"
    134. [ 160.676] (**) NVIDIA(1): Option "MultiGPU" "Off"
    135. [ 160.676] (**) NVIDIA(1): Option "BaseMosaic" "off"
    136. [ 160.676] (**) NVIDIA(1): Stereo disabled by request
    137. [ 160.677] (**) NVIDIA(1): NVIDIA SLI disabled.
    138. [ 160.677] (**) NVIDIA(1): NVIDIA Multi-GPU disabled.
    139. [ 160.677] (II) NVIDIA(1): NVIDIA GPU GeForce GT 710 (GK208) at PCI:11:0:0 (GPU-0)
    140. [ 160.677] (--) NVIDIA(1): Memory: 2097152 kBytes
    141. [ 160.677] (--) NVIDIA(1): VideoBIOS: 80.28.a6.00.15
    142. [ 160.677] (II) NVIDIA(1): Detected PCI Express Link width: 8X
    143. [ 160.718] (II) NVIDIA(1): Validated MetaModes:
    144. [ 160.719] (II) NVIDIA(1): "HDMI-0:nvidia-auto-select+0+0"
    145. [ 160.719] (II) NVIDIA(1): Virtual screen size determined to be 1440 x 900
    146. [ 160.785] (--) NVIDIA(1): DPI set to (89, 87); computed from "UseEdidDpi" X config[/COLOR]
    147. [ 160.785] (--) NVIDIA(1): option
    148. [ 160.798] (II) NVIDIA: Using 6144.00 MB of virtual memory for indirect memory
    149. [ 160.798] (II) NVIDIA: access.
    150.
    I'm most interested in the gpu and monitor sections.
    https://wiki.gentoo.org/wiki/Xorg/Guide
  10. frank55
    Dec 6, 2013
    301
    10
  11. frank55
    Dec 6, 2013
    301
    10
    Thank
    E: Package 'xrandr' has no installation candidate
    frank@frank-ET1331G:~$ sudo apt-get install x11-xserver-utils:i386 x11-xserver-utils
    Reading package lists... Done
    Building dependency tree
    Reading state information... Done
    x11-xserver-utils is already the newest version (7.7+7build1).
    Some packages could not be installed. This may mean that you have
    requested an impossible situation or if you are using the unstable
    distribution that some required packages have not yet been created
    or been moved out of Incoming.
    The following information may help to resolve the situation:
    The following packages have unmet dependencies:
    x11-xserver-utils : Conflicts: x11-xserver-utils:i386 but 7.7+7build1 is to be installed
    x11-xserver-utils:i386 : Depends: cpp:i386 but it is not going to be installed
    Conflicts: x11-xserver-utils but 7.7+7build1 is to be installed
    E: Unable to correct problems, you have held broken packages.
  12. frank55
    Dec 6, 2013
    301
    10
    Thanks Nsaspook ,upon rebooting with both monitors on and set AOC primary monitor and the other monitor mirrored of this ,i was able to get full screen with 1600-900 resolution i can see the full screen but on the bottom screen is cut off about 5 inch and on the right side about 2 inch,if i lower resolution it gets worse, also xrandr doesn't exist,
    Code (Text):
    1.
    2. frank@frank-ET1331G:~$ cat /var/log/Xorg.0.log.old
    3. [   757.211]
    4. X.Org X Server 1.19.6
    5. Release Date: 2017-12-20
    6. [   757.211] X Protocol Version 11, Revision 0
    7. [   757.211] Build Operating System: Linux 4.4.0-138-generic x86_64 Ubuntu
    8. [   757.211] Current Operating System: Linux frank-ET1331G 4.15.0-43-generic #46-Ubuntu SMP Thu Dec 6 14:45:28 UTC 2018 x86_64
    9. [   757.211] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-43-generic root=UUID=57e5392d-c846-4374-bbaa-94b71385ca04 ro quiet splash vt.handoff=1
    10. [   757.211] Build Date: 25 October 2018  04:11:27PM
    11. [   757.211] xorg-server 2:1.19.6-1ubuntu4.2 (For technical support please see [URL]http://www.ubuntu.com/support[/URL])
    12. [   757.212] Current version of pixman: 0.34.0
    13. [   757.212]     Before reporting problems, check [URL]http://wiki.x.org[/URL]
    14.     to make sure that you have the latest version.
    15. [   757.212] Markers: (--) probed, (**) from config file, (==) default setting,
    16.     (++) from command line, (!!) notice, (II) informational,
    17.     (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
    18. [   757.212] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Jan 11 12:16:30 2019
    19. [   757.212] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
    20. [   757.212] (==) No Layout section.  Using the first Screen section.
    21. [   757.212] (==) No screen section available. Using defaults.
    22. [   757.212] (**) |-->Screen "Default Screen Section" (0)
    23. [   757.212] (**) |   |-->Monitor "<default monitor>"
    24. [   757.213] (==) No monitor specified for screen "Default Screen Section".
    25.     Using a default monitor configuration.
    26. [   757.213] (==) Automatically adding devices
    27. [   757.213] (==) Automatically enabling devices
    28. [   757.213] (==) Automatically adding GPU devices
    29. [   757.213] (==) Automatically binding GPU devices
    30. [   757.213] (==) Max clients allowed: 256, resource mask: 0x1fffff
    31. [   757.213] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
    32. [   757.213]     Entry deleted from font path.
    33. [   757.213] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
    34. [   757.213]     Entry deleted from font path.
    35. [   757.213] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
    36. [   757.213]     Entry deleted from font path.
    37. [   757.213] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
    38. [   757.213]     Entry deleted from font path.
    39. [   757.213] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
    40. [   757.213]     Entry deleted from font path.
    41. [   757.213] (==) FontPath set to:
    42.     /usr/share/fonts/X11/misc,
    43.     /usr/share/fonts/X11/Type1,
    44.     built-ins
    45. [   757.213] (==) ModulePath set to "/usr/lib/xorg/modules"
    46. [   757.213] (II) The server relies on udev to provide the list of input devices.
    47.     If no devices become available, reconfigure udev or disable AutoAddDevices.
    48. [   757.213] (II) Loader magic: 0x556b21962020
    49. [   757.213] (II) Module ABI versions:
    50. [   757.213]     X.Org ANSI C Emulation: 0.4
    51. [   757.213]     X.Org Video Driver: 23.0
    52. [   757.213]     X.Org XInput driver : 24.1
    53. [   757.213]     X.Org Server Extension : 10.0
    54. [   757.215] (++) using VT number 7
    55.
    56. [   757.216] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
    57. [   757.217] (II) xfree86: Adding drm device (/dev/dri/card0)
    58. [   757.224] (--) PCI:*(0:2:0:0) 1002:71c1:174b:0840 rev 158, Mem @ 0xc0000000/268435456, 0xdfff0000/65536, I/O @ 0x0000e000/256, BIOS @ 0x????????/131072
    59. [   757.224] (--) PCI: (0:2:0:1) 1002:71e1:174b:0841 rev 158, Mem @ 0xdffe0000/65536
    60. [   757.224] (II) LoadModule: "glx"
    61. [   757.225] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
    62. [   757.226] (II) Module glx: vendor="X.Org Foundation"
    63. [   757.226]     compiled for 1.19.6, module version = 1.0.0
    64. [   757.226]     ABI class: X.Org Server Extension, version 10.0
    65. [   757.226] (II) Applying OutputClass "Radeon" to /dev/dri/card0
    66. [   757.226]     loading driver: radeon
    67. [   757.226] (==) Matched radeon as autoconfigured driver 0
    68. [   757.226] (==) Matched ati as autoconfigured driver 1
    69. [   757.226] (==) Matched ati as autoconfigured driver 2
    70. [   757.226] (==) Matched modesetting as autoconfigured driver 3
    71. [   757.226] (==) Matched fbdev as autoconfigured driver 4
    72. [   757.226] (==) Matched vesa as autoconfigured driver 5
    73. [   757.226] (==) Assigned the driver to the xf86ConfigLayout
    74. [   757.226] (II) LoadModule: "radeon"
    75. [   757.226] (II) Loading /usr/lib/xorg/modules/drivers/radeon_drv.so
    76. [   757.227] (II) Module radeon: vendor="X.Org Foundation"
    77. [   757.227]     compiled for 1.19.6, module version = 18.1.99
    78. [   757.227]     Module class: X.Org Video Driver
    79. [   757.227]     ABI class: X.Org Video Driver, version 23.0
    80. [   757.227] (II) LoadModule: "ati"
    81. [   757.227] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
    82. [   757.227] (II) Module ati: vendor="X.Org Foundation"
    83. [   757.227]     compiled for 1.19.6, module version = 18.1.99
    84. [   757.227]     Module class: X.Org Video Driver
    85. [   757.227]     ABI class: X.Org Video Driver, version 23.0
    86. [   757.324] (II) LoadModule: "modesetting"
    87. [   757.324] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
    88. [   757.324] (II) Module modesetting: vendor="X.Org Foundation"
    89. [   757.324]     compiled for 1.19.6, module version = 1.19.6
    90. [   757.324]     Module class: X.Org Video Driver
    91. [   757.324]     ABI class: X.Org Video Driver, version 23.0
    92. [   757.324] (II) LoadModule: "fbdev"
    93. [   757.324] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
    94. [   757.324] (II) Module fbdev: vendor="X.Org Foundation"
    95. [   757.324]     compiled for 1.19.3, module version = 0.4.4
    96. [   757.324]     Module class: X.Org Video Driver
    97. [   757.324]     ABI class: X.Org Video Driver, version 23.0
    98. [   757.325] (II) LoadModule: "vesa"
    99. [   757.325] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
    100. [   757.325] (II) Module vesa: vendor="X.Org Foundation"
    101. [   757.325]     compiled for 1.19.3, module version = 2.3.4
    102. [   757.325]     Module class: X.Org Video Driver
    103. [   757.325]     ABI class: X.Org Video Driver, version 23.0
    104. [   757.325] (II) RADEON: Driver for ATI/AMD Radeon chipsets:
    105.     ATI Radeon Mobility X600 (M24), ATI FireMV 2400,
    106.     ATI Radeon Mobility X300 (M24), ATI FireGL M24 GL,
    107.     ATI Radeon X600 (RV380), ATI FireGL V3200 (RV380),
    108.     ATI Radeon IGP320 (A3), ATI Radeon IGP330/340/350 (A4),
    109.     ATI Radeon 9500, ATI Radeon 9600TX, ATI FireGL Z1, ATI Radeon 9800SE,
    110.     ATI Radeon 9800, ATI FireGL X2, ATI Radeon 9600, ATI Radeon 9600SE,
    111.     ATI Radeon 9600XT, ATI FireGL T2, ATI Radeon 9650, ATI FireGL RV360,
    112.     ATI Radeon 7000 IGP (A4+), ATI Radeon 8500 AIW,
    113.     ATI Radeon IGP320M (U1), ATI Radeon IGP330M/340M/350M (U2),
    114.     ATI Radeon Mobility 7000 IGP, ATI Radeon 9000/PRO, ATI Radeon 9000,
    115.     ATI Radeon X800 (R420), ATI Radeon X800PRO (R420),
    116.     ATI Radeon X800SE (R420), ATI FireGL X3 (R420),
    117.     ATI Radeon Mobility 9800 (M18), ATI Radeon X800 SE (R420),
    118.     ATI Radeon X800XT (R420), ATI Radeon X800 VE (R420),
    119.     ATI Radeon X850 (R480), ATI Radeon X850 XT (R480),
    120.     ATI Radeon X850 SE (R480), ATI Radeon X850 PRO (R480),
    121.     ATI Radeon X850 XT PE (R480), ATI Radeon Mobility M7,
    122.     ATI Mobility FireGL 7800 M7, ATI Radeon Mobility M6,
    123.     ATI FireGL Mobility 9000 (M9), ATI Radeon Mobility 9000 (M9),
    124.     ATI Radeon 9700 Pro, ATI Radeon 9700/9500Pro, ATI FireGL X1,
    125.     ATI Radeon 9800PRO, ATI Radeon 9800XT,
    126.     ATI Radeon Mobility 9600/9700 (M10/M11),
    127.     ATI Radeon Mobility 9600 (M10), ATI Radeon Mobility 9600 (M11),
    128.     ATI FireGL Mobility T2 (M10), ATI FireGL Mobility T2e (M11),
    129.     ATI Radeon, ATI FireGL 8700/8800, ATI Radeon 8500, ATI Radeon 9100,
    130.     ATI Radeon 7500, ATI Radeon VE/7000, ATI ES1000,
    131.     ATI Radeon Mobility X300 (M22), ATI Radeon Mobility X600 SE (M24C),
    132.     ATI FireGL M22 GL, ATI Radeon X800 (R423), ATI Radeon X800PRO (R423),
    133.     ATI Radeon X800LE (R423), ATI Radeon X800SE (R423),
    134.     ATI Radeon X800 XTP (R430), ATI Radeon X800 XL (R430),
    135.     ATI Radeon X800 SE (R430), ATI Radeon X800 (R430),
    136.     ATI FireGL V7100 (R423), ATI FireGL V5100 (R423),
    137.     ATI FireGL unknown (R423), ATI Mobility FireGL V5000 (M26),
    138.     ATI Mobility Radeon X700 XL (M26), ATI Mobility Radeon X700 (M26),
    139.     ATI Radeon X550XTX, ATI Radeon 9100 IGP (A5),
    140.     ATI Radeon Mobility 9100 IGP (U3), ATI Radeon XPRESS 200,
    141.     ATI Radeon XPRESS 200M, ATI Radeon 9250, ATI Radeon 9200,
    142.     ATI Radeon 9200SE, ATI FireMV 2200, ATI Radeon X300 (RV370),
    143.     ATI Radeon X600 (RV370), ATI Radeon X550 (RV370),
    144.     ATI FireGL V3100 (RV370), ATI FireMV 2200 PCIE (RV370),
    145.     ATI Radeon Mobility 9200 (M9+), ATI Mobility Radeon X800 XT (M28),
    146.     ATI Mobility FireGL V5100 (M28), ATI Mobility Radeon X800 (M28),
    147.     ATI Radeon X850, ATI unknown Radeon / FireGL (R480),
    148.     ATI Radeon X800XT (R423), ATI FireGL V5000 (RV410),
    149.     ATI Radeon X700 XT (RV410), ATI Radeon X700 PRO (RV410),
    150.     ATI Radeon X700 SE (RV410), ATI Radeon X700 (RV410),
    151.     ATI Radeon X1800, ATI Mobility Radeon X1800 XT,
    152.     ATI Mobility Radeon X1800, ATI Mobility FireGL V7200,
    153.     ATI FireGL V7200, ATI FireGL V5300, ATI Mobility FireGL V7100,
    154.     ATI FireGL V7300, ATI FireGL V7350, ATI Radeon X1600, ATI RV505,
    155.     ATI Radeon X1300/X1550, ATI Radeon X1550, ATI M54-GL,
    156.     ATI Mobility Radeon X1400, ATI Radeon X1550 64-bit,
    157.     ATI Mobility Radeon X1300, ATI Radeon X1300, ATI FireGL V3300,
    158.     ATI FireGL V3350, ATI Mobility Radeon X1450,
    159.     ATI Mobility Radeon X2300, ATI Mobility Radeon X1350,
    160.     ATI FireMV 2250, ATI Radeon X1650, ATI Mobility FireGL V5200,
    161.     ATI Mobility Radeon X1600, ATI Radeon X1300 XT/X1600 Pro,
    162.     ATI FireGL V3400, ATI Mobility FireGL V5250,
    163.     ATI Mobility Radeon X1700, ATI Mobility Radeon X1700 XT,
    164.     ATI FireGL V5200, ATI Radeon X2300HD, ATI Mobility Radeon HD 2300,
    165.     ATI Radeon X1950, ATI Radeon X1900, ATI AMD Stream Processor,
    166.     ATI RV560, ATI Mobility Radeon X1900, ATI Radeon X1950 GT, ATI RV570,
    167.     ATI FireGL V7400, ATI Radeon 9100 PRO IGP,
    168.     ATI Radeon Mobility 9200 IGP, ATI Radeon X1200, ATI RS740,
    169.     ATI RS740M, ATI Radeon HD 2900 XT, ATI Radeon HD 2900 Pro,
    170.     ATI Radeon HD 2900 GT, ATI FireGL V8650, ATI FireGL V8600,
    171.     ATI FireGL V7600, ATI Radeon 4800 Series, ATI Radeon HD 4870 x2,
    172.     ATI Radeon HD 4850 x2, ATI FirePro V8750 (FireGL),
    173.     ATI FirePro V7760 (FireGL), ATI Mobility RADEON HD 4850,
    174.     ATI Mobility RADEON HD 4850 X2, ATI FirePro RV770,
    175.     AMD FireStream 9270, AMD FireStream 9250, ATI FirePro V8700 (FireGL),
    176.     ATI Mobility RADEON HD 4870, ATI Mobility RADEON M98,
    177.     ATI FirePro M7750, ATI M98, ATI Mobility Radeon HD 4650,
    178.     ATI Radeon RV730 (AGP), ATI Mobility Radeon HD 4670,
    179.     ATI FirePro M5750, ATI RV730XT [Radeon HD 4670], ATI RADEON E4600,
    180.     ATI Radeon HD 4600 Series, ATI RV730 PRO [Radeon HD 4650],
    181.     ATI FirePro V7750 (FireGL), ATI FirePro V5700 (FireGL),
    182.     ATI FirePro V3750 (FireGL), ATI Mobility Radeon HD 4830,
    183.     ATI Mobility Radeon HD 4850, ATI FirePro M7740, ATI RV740,
    184.     ATI Radeon HD 4770, ATI Radeon HD 4700 Series, ATI RV610,
    185.     ATI Radeon HD 2400 XT, ATI Radeon HD 2400 Pro,
    186.     ATI Radeon HD 2400 PRO AGP, ATI FireGL V4000, ATI Radeon HD 2350,
    187.     ATI Mobility Radeon HD 2400 XT, ATI Mobility Radeon HD 2400,
    188.     ATI RADEON E2400, ATI FireMV 2260, ATI RV670, ATI Radeon HD3870,
    189.     ATI Mobility Radeon HD 3850, ATI Radeon HD3850,
    190.     ATI Mobility Radeon HD 3850 X2, ATI Mobility Radeon HD 3870,
    191.     ATI Mobility Radeon HD 3870 X2, ATI Radeon HD3870 X2,
    192.     ATI FireGL V7700, ATI Radeon HD3690, AMD Firestream 9170,
    193.     ATI Radeon HD 4550, ATI Radeon RV710, ATI Radeon HD 4350,
    194.     ATI Mobility Radeon 4300 Series, ATI Mobility Radeon 4500 Series,
    195.     ATI FirePro RG220, ATI Mobility Radeon 4330, ATI RV630,
    196.     ATI Mobility Radeon HD 2600, ATI Mobility Radeon HD 2600 XT,
    197.     ATI Radeon HD 2600 XT AGP, ATI Radeon HD 2600 Pro AGP,
    198.     ATI Radeon HD 2600 XT, ATI Radeon HD 2600 Pro, ATI Gemini RV630,
    199.     ATI Gemini Mobility Radeon HD 2600 XT, ATI FireGL V5600,
    200.     ATI FireGL V3600, ATI Radeon HD 2600 LE,
    201.     ATI Mobility FireGL Graphics Processor, ATI Radeon HD 3470,
    202.     ATI Mobility Radeon HD 3430, ATI Mobility Radeon HD 3400 Series,
    203.     ATI Radeon HD 3450, ATI Radeon HD 3430, ATI FirePro V3700,
    204.     ATI FireMV 2450, ATI Radeon HD 3600 Series, ATI Radeon HD 3650 AGP,
    205.     ATI Radeon HD 3600 PRO, ATI Radeon HD 3600 XT,
    206.     ATI Mobility Radeon HD 3650, ATI Mobility Radeon HD 3670,
    207.     ATI Mobility FireGL V5700, ATI Mobility FireGL V5725,
    208.     ATI Radeon HD 3200 Graphics, ATI Radeon 3100 Graphics,
    209.     ATI Radeon HD 3300 Graphics, ATI Radeon 3000 Graphics, SUMO, SUMO2,
    210.     ATI Radeon HD 4200, ATI Radeon 4100, ATI Mobility Radeon HD 4200,
    211.     ATI Mobility Radeon 4100, ATI Radeon HD 4290, ATI Radeon HD 4250,
    212.     AMD Radeon HD 6310 Graphics, AMD Radeon HD 6250 Graphics,
    213.     AMD Radeon HD 6300 Series Graphics,
    214.     AMD Radeon HD 6200 Series Graphics, PALM, CYPRESS,
    215.     ATI FirePro (FireGL) Graphics Adapter, AMD Firestream 9370,
    216.     AMD Firestream 9350, ATI Radeon HD 5800 Series,
    217.     ATI Radeon HD 5900 Series, ATI Mobility Radeon HD 5800 Series,
    218.     ATI Radeon HD 5700 Series, ATI Radeon HD 6700 Series,
    219.     ATI Mobility Radeon HD 5000 Series, ATI Mobility Radeon HD 5570,
    220.     ATI Radeon HD 5670, ATI Radeon HD 5570, ATI Radeon HD 5500 Series,
    221.     REDWOOD, ATI Mobility Radeon Graphics, CEDAR, ATI FirePro 2270,
    222.     ATI Radeon HD 5450, CAYMAN, AMD Radeon HD 6900 Series,
    223.     AMD Radeon HD 6900M Series, Mobility Radeon HD 6000 Series, BARTS,
    224.     AMD Radeon HD 6800 Series, AMD Radeon HD 6700 Series, TURKS, CAICOS,
    225.     ARUBA, TAHITI, PITCAIRN, VERDE, OLAND, HAINAN, BONAIRE, KABINI,
    226.     MULLINS, KAVERI, HAWAII
    227. [   757.329] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
    228. [   757.329] (II) FBDEV: driver for framebuffer: fbdev
    229. [   757.329] (II) VESA: driver for VESA chipsets: vesa
    230. [   757.330] (II) [KMS] Kernel modesetting enabled.
    231. [   757.330] (WW) Falling back to old probe method for modesetting
    232. [   757.330] (WW) Falling back to old probe method for fbdev
    233. [   757.330] (II) Loading sub module "fbdevhw"
    234. [   757.330] (II) LoadModule: "fbdevhw"
    235. [   757.330] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
    236. [   757.330] (II) Module fbdevhw: vendor="X.Org Foundation"
    237. [   757.330]     compiled for 1.19.6, module version = 0.0.2
    238. [   757.330]     ABI class: X.Org Video Driver, version 23.0
    239. [   757.330] (WW) Falling back to old probe method for vesa
    240. [   757.330] (II) RADEON(0): Creating default Display subsection in Screen section
    241.     "Default Screen Section" for depth/fbbpp 24/32
    242. [   757.330] (==) RADEON(0): Depth 24, (--) framebuffer bpp 32
    243. [   757.330] (II) RADEON(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
    244. [   757.330] (==) RADEON(0): Default visual is TrueColor
    245. [   757.330] (==) RADEON(0): RGB weight 888
    246. [   757.330] (II) RADEON(0): Using 8 bits per RGB (8 bit DAC)
    247. [   757.330] (--) RADEON(0): Chipset: "ATI Radeon X1650" (ChipID = 0x71c1)
    248. [   757.330] (II) Loading sub module "fb"
    249. [   757.330] (II) LoadModule: "fb"
    250. [   757.330] (II) Loading /usr/lib/xorg/modules/libfb.so
    251. [   757.331] (II) Module fb: vendor="X.Org Foundation"
    252. [   757.331]     compiled for 1.19.6, module version = 1.0.0
    253. [   757.331]     ABI class: X.Org ANSI C Emulation, version 0.4
    254. [   757.331] (II) Loading sub module "dri2"
    255. [   757.331] (II) LoadModule: "dri2"
    256. [   757.331] (II) Module "dri2" already built-in
    257. [   757.331] (II) Loading sub module "exa"
    258. [   757.331] (II) LoadModule: "exa"
    259. [   757.331] (II) Loading /usr/lib/xorg/modules/libexa.so
    260. [   757.331] (II) Module exa: vendor="X.Org Foundation"
    261. [   757.331]     compiled for 1.19.6, module version = 2.6.0
    262. [   757.331]     ABI class: X.Org Video Driver, version 23.0
    263. [   757.331] (II) RADEON(0): KMS Color Tiling: enabled
    264. [   757.331] (II) RADEON(0): KMS Color Tiling 2D: disabled
    265. [   757.331] (==) RADEON(0): TearFree property default: auto
    266. [   757.331] (II) RADEON(0): KMS Pageflipping: enabled
    267. [   757.331] (II) RADEON(0): SwapBuffers wait for vsync: enabled
    268. [   757.362] (II) RADEON(0): Output DVI-0 has no monitor section
    269. [   757.392] (II) RADEON(0): Output S-video has no monitor section
    270. [   757.424] (II) RADEON(0): Output DVI-1 has no monitor section
    271. [   757.424] (WW) RADEON(0): 3 ZaphodHeads crtcs unavailable. Some outputs will stay off.
    272. [   757.455] (II) RADEON(0): EDID for output DVI-0
    273. [   757.455] (II) RADEON(0): Manufacturer: AOC  Model: 2050  Serial#: 25497
    274. [   757.455] (II) RADEON(0): Year: 2014  Week: 3
    275. [   757.455] (II) RADEON(0): EDID Version: 1.3
    276. [   757.455] (II) RADEON(0): Digital Display Input
    277. [   757.455] (II) RADEON(0): Max Image Size [cm]: horiz.: 43  vert.: 24
    278. [   757.455] (II) RADEON(0): Gamma: 2.20
    279. [   757.455] (II) RADEON(0): DPMS capabilities: Off
    280. [   757.455] (II) RADEON(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
    281. [   757.455] (II) RADEON(0): First detailed timing is preferred mode
    282. [   757.455] (II) RADEON(0): redX: 0.641 redY: 0.338   greenX: 0.315 greenY: 0.629
    283. [   757.455] (II) RADEON(0): blueX: 0.159 blueY: 0.059   whiteX: 0.313 whiteY: 0.329
    284. [   757.455] (II) RADEON(0): Supported established timings:
    285. [   757.455] (II) RADEON(0): 720x400@70Hz
    286. [   757.455] (II) RADEON(0): 640x480@60Hz
    287. [   757.455] (II) RADEON(0): 640x480@67Hz
    288. [   757.455] (II) RADEON(0): 640x480@72Hz
    289. [   757.455] (II) RADEON(0): 640x480@75Hz
    290. [   757.455] (II) RADEON(0): 800x600@56Hz
    291. [   757.455] (II) RADEON(0): 800x600@60Hz
    292. [   757.455] (II) RADEON(0): 800x600@72Hz
    293. [   757.455] (II) RADEON(0): 800x600@75Hz
    294. [   757.455] (II) RADEON(0): 832x624@75Hz
    295. [   757.455] (II) RADEON(0): 1024x768@60Hz
    296. [   757.455] (II) RADEON(0): 1024x768@70Hz
    297. [   757.455] (II) RADEON(0): 1024x768@75Hz
    298. [   757.455] (II) RADEON(0): 1280x1024@75Hz
    299. [   757.455] (II) RADEON(0): Manufacturer's mask: 0
    300. [   757.455] (II) RADEON(0): Supported standard timings:
    301. [   757.455] (II) RADEON(0): #0: hsize: 1600  vsize 900  refresh: 60  vid: 49321
    302. [   757.455] (II) RADEON(0): #1: hsize: 1280  vsize 1024  refresh: 60  vid: 32897
    303. [   757.455] (II) RADEON(0): #2: hsize: 1280  vsize 720  refresh: 60  vid: 49281
    304. [   757.455] (II) RADEON(0): Supported detailed timing:
    305. [   757.455] (II) RADEON(0): clock: 108.0 MHz   Image Size:  432 x 240 mm
    306. [   757.455] (II) RADEON(0): h_active: 1600  h_sync: 1624  h_sync_end 1704 h_blank_end 1800 h_border: 0
    307. [   757.455] (II) RADEON(0): v_active: 900  v_sync: 901  v_sync_end 904 v_blanking: 1000 v_border: 0
    308. [   757.455] (II) RADEON(0): Ranges: V min: 50 V max: 76 Hz, H min: 30 H max: 83 kHz, PixClock max 145 MHz
    309. [   757.455] (II) RADEON(0): Monitor name: 2050W
    310. [   757.455] (II) RADEON(0): Serial No: FSGE1HA025497
    311. [   757.455] (II) RADEON(0): EDID (in hex):
    312. [   757.455] (II) RADEON(0):     00ffffffffffff0005e3502099630000
    313. [   757.455] (II) RADEON(0):     03180103802b18782a2cc5a45650a128
    314. [   757.455] (II) RADEON(0):     0f5054bfef00a9c0818081c001010101
    315. [   757.456] (II) RADEON(0):     010101010101302a40c8608464301850
    316. [   757.456] (II) RADEON(0):     1300b0f01000001e000000fd00324c1e
    317. [   757.456] (II) RADEON(0):     530e000a202020202020000000fc0032
    318. [   757.456] (II) RADEON(0):     303530570a20202020202020000000ff
    319. [   757.456] (II) RADEON(0):     00465347453148413032353439370010
    320. [   757.456] (II) RADEON(0): Printing probed modes for output DVI-0
    321. [   757.456] (II) RADEON(0): Modeline "1600x900"x60.0  108.00  1600 1624 1704 1800  900 901 904 1000 +hsync +vsync (60.0 kHz eP)
    322. [   757.456] (II) RADEON(0): Modeline "1280x1024"x75.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
    323. [   757.456] (II) RADEON(0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
    324. [   757.456] (II) RADEON(0): Modeline "1280x720"x60.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
    325. [   757.456] (II) RADEON(0): Modeline "1024x768"x75.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
    326. [   757.456] (II) RADEON(0): Modeline "1024x768"x70.1   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
    327. [   757.456] (II) RADEON(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
    328. [   757.456] (II) RADEON(0): Modeline "832x624"x74.6   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
    329. [   757.456] (II) RADEON(0): Modeline "800x600"x72.2   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
    330. [   757.456] (II) RADEON(0): Modeline "800x600"x75.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
    331. [   757.456] (II) RADEON(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
    332. [   757.456] (II) RADEON(0): Modeline "800x600"x56.2   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
    333. [   757.456] (II) RADEON(0): Modeline "640x480"x75.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
    334. [   757.456] (II) RADEON(0): Modeline "640x480"x72.8   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz e)
    335. [   757.456] (II) RADEON(0): Modeline "640x480"x66.7   30.24  640 704 768 864  480 483 486 525 -hsync -vsync (35.0 kHz e)
    336. [   757.456] (II) RADEON(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
    337. [   757.456] (II) RADEON(0): Modeline "720x400"x70.1   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
    338. [   757.488] (II) RADEON(0): EDID for output S-video
    339. [   757.520] (II) RADEON(0): EDID for output DVI-1
    340. [   757.520] (II) RADEON(0): Manufacturer: PTS  Model: 7d1  Serial#: 16843009
    341. [   757.520] (II) RADEON(0): Year: 2007  Week: 27
    342. [   757.520] (II) RADEON(0): EDID Version: 1.3
    343. [   757.520] (II) RADEON(0): Digital Display Input
    344. [   757.520] (II) RADEON(0): Max Image Size [cm]: horiz.: 43  vert.: 27
    345. [   757.520] (II) RADEON(0): Gamma: 2.20
    346. [   757.520] (II) RADEON(0): DPMS capabilities: StandBy Suspend Off
    347. [   757.520] (II) RADEON(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
    348. [   757.520] (II) RADEON(0): First detailed timing is preferred mode
    349. [   757.520] (II) RADEON(0): redX: 0.640 redY: 0.352   greenX: 0.288 greenY: 0.628
    350. [   757.520] (II) RADEON(0): blueX: 0.144 blueY: 0.076   whiteX: 0.313 whiteY: 0.329
    351. [   757.520] (II) RADEON(0): Supported established timings:
    352. [   757.520] (II) RADEON(0): 720x400@70Hz
    353. [   757.520] (II) RADEON(0): 640x480@60Hz
    354. [   757.520] (II) RADEON(0): 640x480@75Hz
    355. [   757.520] (II) RADEON(0): 800x600@60Hz
    356. [   757.520] (II) RADEON(0): 800x600@75Hz
    357. [   757.520] (II) RADEON(0): 1024x768@60Hz
    358. [   757.520] (II) RADEON(0): 1024x768@75Hz
    359. [   757.520] (II) RADEON(0): 1280x1024@75Hz
    360. [   757.520] (II) RADEON(0): Manufacturer's mask: 0
    361. [   757.520] (II) RADEON(0): Supported standard timings:
    362. [   757.520] (II) RADEON(0): #0: hsize: 1280  vsize 1024  refresh: 60  vid: 32897
    363. [   757.520] (II) RADEON(0): #1: hsize: 1680  vsize 1050  refresh: 60  vid: 179
    364. [   757.520] (II) RADEON(0): #2: hsize: 1440  vsize 900  refresh: 60  vid: 149
    365. [   757.520] (II) RADEON(0): #3: hsize: 1440  vsize 900  refresh: 75  vid: 3989
    366. [   757.520] (II) RADEON(0): Supported detailed timing:
    367. [   757.520] (II) RADEON(0): clock: 146.2 MHz   Image Size:  433 x 271 mm
    368. [   757.520] (II) RADEON(0): h_active: 1680  h_sync: 1784  h_sync_end 1960 h_blank_end 2240 h_border: 0
    369. [   757.520] (II) RADEON(0): v_active: 1050  v_sync: 1053  v_sync_end 1059 v_blanking: 1089 v_border: 0
    370. [   757.520] (II) RADEON(0): Supported detailed timing:
    371. [   757.520] (II) RADEON(0): clock: 106.5 MHz   Image Size:  433 x 271 mm
    372. [   757.520] (II) RADEON(0): h_active: 1440  h_sync: 1520  h_sync_end 1672 h_blank_end 1904 h_border: 0
    373. [   757.520] (II) RADEON(0): v_active: 900  v_sync: 903  v_sync_end 909 v_blanking: 934 v_border: 0
    374. [   757.520] (II) RADEON(0): Ranges: V min: 56 V max: 76 Hz, H min: 31 H max: 80 kHz, PixClock max 155 MHz
    375. [   757.520] (II) RADEON(0): Serial No: FVYU77013562U
    376. [   757.520] (II) RADEON(0): EDID (in hex):
    377. [   757.520] (II) RADEON(0):     00ffffffffffff004293d10701010101
    378. [   757.520] (II) RADEON(0):     1b110103802b1b78eacfe5a35a49a024
    379. [   757.520] (II) RADEON(0):     135054a54b008180b3009500950f0101
    380. [   757.520] (II) RADEON(0):     01010101010121399030621a274068b0
    381. [   757.520] (II) RADEON(0):     3600b10f1100001c9a29a0d051842230
    382. [   757.520] (II) RADEON(0):     50983600b10f1100001c000000fd0038
    383. [   757.520] (II) RADEON(0):     4c1f500f000a202020202020000000ff
    384. [   757.520] (II) RADEON(0):     00465659553737303133353632550000
    385. [   757.520] (II) RADEON(0): Printing probed modes for output DVI-1
    386. [   757.520] (II) RADEON(0): Modeline "1680x1050"x60.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz eP)
    387. [   757.521] (II) RADEON(0): Modeline "1280x1024"x75.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
    388. [   757.521] (II) RADEON(0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
    389. [   757.521] (II) RADEON(0): Modeline "1440x900"x75.0  136.75  1440 1536 1688 1936  900 903 909 942 -hsync +vsync (70.6 kHz e)
    390. [   757.521] (II) RADEON(0): Modeline "1440x900"x59.9  106.50  1440 1520 1672 1904  900 903 909 934 -hsync +vsync (55.9 kHz e)
    391. [   757.521] (II) RADEON(0): Modeline "1024x768"x75.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
    392. [   757.521] (II) RADEON(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
    393. [   757.521] (II) RADEON(0): Modeline "800x600"x75.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
    394. [   757.521] (II) RADEON(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
    395. [   757.521] (II) RADEON(0): Modeline "640x480"x75.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
    396. [   757.521] (II) RADEON(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
    397. [   757.521] (II) RADEON(0): Modeline "720x400"x70.1   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
    398. [   757.521] (II) RADEON(0): Output DVI-0 connected
    399. [   757.521] (II) RADEON(0): Output S-video disconnected
    400. [   757.521] (II) RADEON(0): Output DVI-1 connected
    401. [   757.521] (II) RADEON(0): Using spanning desktop for initial modes
    402. [   757.521] (II) RADEON(0): Output DVI-0 using initial mode 1600x900 +0+0
    403. [   757.521] (II) RADEON(0): Output DVI-1 using initial mode 1680x1050 +1600+0
    404. [   757.521] (II) RADEON(0): mem size init: gart size :1fdff000 vram size: s:20000000 visible:f854000
    405. [   757.521] (II) RADEON(0): EXA: Driver will allow EXA pixmaps in VRAM
    406. [   757.521] (==) RADEON(0): DPI set to (96, 96)
    407. [   757.521] (==) RADEON(0): Using gamma correction (1.0, 1.0, 1.0)
    408. [   757.521] (II) Loading sub module "ramdac"
    409. [   757.521] (II) LoadModule: "ramdac"
    410. [   757.521] (II) Module "ramdac" already built-in
    411. [   757.521] (II) UnloadModule: "modesetting"
    412. [   757.521] (II) Unloading modesetting
    413. [   757.521] (II) UnloadModule: "fbdev"
    414. [   757.521] (II) Unloading fbdev
    415. [   757.521] (II) UnloadSubModule: "fbdevhw"
    416. [   757.521] (II) Unloading fbdevhw
    417. [   757.521] (II) UnloadModule: "vesa"
    418. [   757.521] (II) Unloading vesa
    419. [   757.521] (--) Depth 24 pixmap format is 32 bpp
    420. [   757.521] (II) RADEON(0): [DRI2] Setup complete
    421. [   757.521] (II) RADEON(0): [DRI2]   DRI driver: r300
    422. [   757.521] (II) RADEON(0): [DRI2]   VDPAU driver: r300
    423. [   757.522] (II) RADEON(0): Front buffer size: 13650K
    424. [   757.522] (II) RADEON(0): VRAM usage limit set to 216545K
    425. [   757.522] (==) RADEON(0): DRI3 disabled
    426. [   757.522] (==) RADEON(0): Backing store enabled
    427. [   757.522] (II) RADEON(0): Direct rendering enabled
    428. [   757.522] (II) RADEON(0): Render acceleration enabled for R300/R400/R500 type cards.
    429. [   757.522] (II) EXA(0): Driver allocated offscreen pixmaps
    430. [   757.522] (II) EXA(0): Driver registered support for the following operations:
    431. [   757.522] (II)         Solid
    432. [   757.522] (II)         Copy
    433. [   757.522] (II)         Composite (RENDER acceleration)
    434. [   757.522] (II)         UploadToScreen
    435. [   757.522] (II)         DownloadFromScreen
    436. [   757.522] (II) RADEON(0): Acceleration enabled
    437. [   757.522] (==) RADEON(0): DPMS enabled
    438. [   757.522] (==) RADEON(0): Silken mouse enabled
    439. [   757.522] (II) RADEON(0): Set up textured video
    440. [   757.522] (II) RADEON(0): [XvMC] Associated with Radeon Textured Video.
    441. [   757.522] (II) RADEON(0): [XvMC] Extension initialized.
    442. [   757.522] (II) RADEON(0): RandR 1.2 enabled, ignore the following RandR disabled message.
    443. [   757.523] (--) RandR disabled
    444. [   757.528] (II) SELinux: Disabled on system
    445. [   757.565] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
    446. [   757.565] (II) AIGLX: enabled GLX_ARB_create_context
    447. [   757.565] (II) AIGLX: enabled GLX_ARB_create_context_profile
    448. [   757.565] (II) AIGLX: enabled GLX_EXT_create_context_es{,2}_profile
    449. [   757.565] (II) AIGLX: enabled GLX_INTEL_swap_event
    450. [   757.565] (II) AIGLX: enabled GLX_SGI_swap_control
    451. [   757.565] (II) AIGLX: enabled GLX_EXT_framebuffer_sRGB
    452. [   757.565] (II) AIGLX: enabled GLX_ARB_fbconfig_float
    453. [   757.565] (II) AIGLX: enabled GLX_EXT_fbconfig_packed_float
    454. [   757.565] (II) AIGLX: GLX_EXT_texture_from_pixmap backed by buffer objects
    455. [   757.568] (II) AIGLX: Loaded and initialized r300
    456. [   757.568] (II) GLX: Initialized DRI2 GL provider for screen 0
    457. [   757.569] (II) RADEON(0): Setting screen physical size to 867 x 277
    458. [   757.649] (II) config/udev: Adding input device Power Button (/dev/input/event1)
    459. [   757.649] (**) Power Button: Applying InputClass "libinput keyboard catchall"
    460. [   757.649] (II) LoadModule: "libinput"
    461. [   757.649] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
    462. [   757.652] (II) Module libinput: vendor="X.Org Foundation"
    463. [   757.652]     compiled for 1.19.6, module version = 0.27.1
    464. [   757.652]     Module class: X.Org XInput Driver
    465. [   757.652]     ABI class: X.Org XInput driver, version 24.1
    466. [   757.652] (II) Using input driver 'libinput' for 'Power Button'
    467. [   757.652] (**) Power Button: always reports core events
    468. [   757.652] (**) Option "Device" "/dev/input/event1"
    469. [   757.652] (**) Option "_source" "server/udev"
    470. [   757.653] (II) event1  - Power Button: is tagged by udev as: Keyboard
    471. [   757.653] (II) event1  - Power Button: device is a keyboard
    472. [   757.653] (II) event1  - Power Button: device removed
    473. [   757.672] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
    474. [   757.672] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
    475. [   757.672] (**) Option "xkb_model" "pc105"
    476. [   757.672] (**) Option "xkb_layout" "us"
    477. [   757.674] (II) event1  - Power Button: is tagged by udev as: Keyboard
    478. [   757.674] (II) event1  - Power Button: device is a keyboard
    479. [   757.675] (II) config/udev: Adding input device Power Button (/dev/input/event0)
    480. [   757.675] (**) Power Button: Applying InputClass "libinput keyboard catchall"
    481. [   757.675] (II) Using input driver 'libinput' for 'Power Button'
    482. [   757.675] (**) Power Button: always reports core events
    483. [   757.675] (**) Option "Device" "/dev/input/event0"
    484. [   757.675] (**) Option "_source" "server/udev"
    485. [   757.676] (II) event0  - Power Button: is tagged by udev as: Keyboard
    486. [   757.676] (II) event0  - Power Button: device is a keyboard
    487. [   757.676] (II) event0  - Power Button: device removed
    488. [   757.696] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
    489. [   757.696] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
    490. [   757.696] (**) Option "xkb_model" "pc105"
    491. [   757.696] (**) Option "xkb_layout" "us"
    492. [   757.698] (II) event0  - Power Button: is tagged by udev as: Keyboard
    493. [   757.698] (II) event0  - Power Button: device is a keyboard
    494. [   757.700] (II) config/udev: Adding input device   USB Keyboard (/dev/input/event2)
    495. [   757.700] (**)   USB Keyboard: Applying InputClass "libinput keyboard catchall"
    496. [   757.700] (II) Using input driver 'libinput' for '  USB Keyboard'
    497. [   757.700] (**)   USB Keyboard: always reports core events
    498. [   757.700] (**) Option "Device" "/dev/input/event2"
    499. [   757.700] (**) Option "_source" "server/udev"
    500. [   757.701] (II) event2  -   USB Keyboard: is tagged by udev as: Keyboard
    501. [   757.701] (II) event2  -   USB Keyboard: device is a keyboard
    502. [   757.701] (II) event2  -   USB Keyboard: device removed
    503. [   757.720] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:02.0/usb2/2-1/2-1:1.0/0003:04D9:1503.0001/input/input5/event2"
    504. [   757.720] (II) XINPUT: Adding extended input device "  USB Keyboard" (type: KEYBOARD, id 8)
    505. [   757.720] (**) Option "xkb_model" "pc105"
    506. [   757.720] (**) Option "xkb_layout" "us"
    507. [   757.722] (II) event2  -   USB Keyboard: is tagged by udev as: Keyboard
    508. [   757.722] (II) event2  -   USB Keyboard: device is a keyboard
    509. [   757.724] (II) config/udev: Adding input device   USB Keyboard (/dev/input/event3)
    510. [   757.724] (**)   USB Keyboard: Applying InputClass "libinput keyboard catchall"
    511. [   757.724] (II) Using input driver 'libinput' for '  USB Keyboard'
    512. [   757.724] (**)   USB Keyboard: always reports core events
    513. [   757.724] (**) Option "Device" "/dev/input/event3"
    514. [   757.724] (**) Option "_source" "server/udev"
    515. [   757.725] (II) event3  -   USB Keyboard: is tagged by udev as: Keyboard
    516. [   757.725] (II) event3  -   USB Keyboard: device is a keyboard
    517. [   757.725] (II) event3  -   USB Keyboard: device removed
    518. [   757.744] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:02.0/usb2/2-1/2-1:1.1/0003:04D9:1503.0002/input/input6/event3"
    519. [   757.744] (II) XINPUT: Adding extended input device "  USB Keyboard" (type: KEYBOARD, id 9)
    520. [   757.744] (**) Option "xkb_model" "pc105"
    521. [   757.744] (**) Option "xkb_layout" "us"
    522. [   757.746] (II) event3  -   USB Keyboard: is tagged by udev as: Keyboard
    523. [   757.746] (II) event3  -   USB Keyboard: device is a keyboard
    524. [   757.748] (II) config/udev: Adding input device C-Media USB Audio Device    (/dev/input/event7)
    525. [   757.748] (**) C-Media USB Audio Device   : Applying InputClass "libinput keyboard catchall"
    526. [   757.748] (II) Using input driver 'libinput' for 'C-Media USB Audio Device   '
    527. [   757.748] (**) C-Media USB Audio Device   : always reports core events
    528. [   757.748] (**) Option "Device" "/dev/input/event7"
    529. [   757.748] (**) Option "_source" "server/udev"
    530. [   757.749] (II) event7  - C-Media USB Audio Device   : is tagged by udev as: Keyboard
    531. [   757.749] (II) event7  - C-Media USB Audio Device   : device is a keyboard
    532. [   757.749] (II) event7  - C-Media USB Audio Device   : device removed
    533. [   757.768] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:02.0/usb2/2-10/2-10:1.3/0003:0D8C:0008.0006/input/input10/event7"
    534. [   757.768] (II) XINPUT: Adding extended input device "C-Media USB Audio Device   " (type: KEYBOARD, id 10)
    535. [   757.768] (**) Option "xkb_model" "pc105"
    536. [   757.768] (**) Option "xkb_layout" "us"
    537. [   757.770] (II) event7  - C-Media USB Audio Device   : is tagged by udev as: Keyboard
    538. [   757.770] (II) event7  - C-Media USB Audio Device   : device is a keyboard
    539. [   757.772] (II) config/udev: Adding input device Dell Dell USB Keyboard (/dev/input/event4)
    540. [   757.772] (**) Dell Dell USB Keyboard: Applying InputClass "libinput keyboard catchall"
    541. [   757.772] (II) Using input driver 'libinput' for 'Dell Dell USB Keyboard'
    542. [   757.772] (**) Dell Dell USB Keyboard: always reports core events
    543. [   757.772] (**) Option "Device" "/dev/input/event4"
    544. [   757.772] (**) Option "_source" "server/udev"
    545. [   757.773] (II) event4  - Dell Dell USB Keyboard: is tagged by udev as: Keyboard
    546. [   757.773] (II) event4  - Dell Dell USB Keyboard: device is a keyboard
    547. [   757.773] (II) event4  - Dell Dell USB Keyboard: device removed
    548. [   757.792] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:02.0/usb2/2-2/2-2:1.0/0003:413C:2105.0003/input/input7/event4"
    549. [   757.792] (II) XINPUT: Adding extended input device "Dell Dell USB Keyboard" (type: KEYBOARD, id 11)
    550. [   757.792] (**) Option "xkb_model" "pc105"
    551. [   757.792] (**) Option "xkb_layout" "us"
    552. [   757.794] (II) event4  - Dell Dell USB Keyboard: is tagged by udev as: Keyboard
    553. [   757.794] (II) event4  - Dell Dell USB Keyboard: device is a keyboard
    554. [   757.796] (II) config/udev: Adding input device PS/2+USB Mouse (/dev/input/event5)
    555. [   757.796] (**) PS/2+USB Mouse: Applying InputClass "libinput pointer catchall"
    556. [   757.796] (II) Using input driver 'libinput' for 'PS/2+USB Mouse'
    557. [   757.796] (**) PS/2+USB Mouse: always reports core events
    558. [   757.796] (**) Option "Device" "/dev/input/event5"
    559. [   757.796] (**) Option "_source" "server/udev"
    560. [   757.857] (II) event5  - PS/2+USB Mouse: is tagged by udev as: Mouse
    561. [   757.857] (II) event5  - PS/2+USB Mouse: device is a pointer
    562. [   757.857] (II) event5  - PS/2+USB Mouse: device removed
    563. [   757.896] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:02.0/usb2/2-3/2-3:1.0/0003:1267:0210.0004/input/input8/event5"
    564. [   757.896] (II) XINPUT: Adding extended input device "PS/2+USB Mouse" (type: MOUSE, id 12)
    565. [   757.897] (**) Option "AccelerationScheme" "none"
    566. [   757.897] (**) PS/2+USB Mouse: (accel) selected scheme none/0
    567. [   757.897] (**) PS/2+USB Mouse: (accel) acceleration factor: 2.000
    568. [   757.897] (**) PS/2+USB Mouse: (accel) acceleration threshold: 4
    569. [   757.957] (II) event5  - PS/2+USB Mouse: is tagged by udev as: Mouse
    570. [   757.957] (II) event5  - PS/2+USB Mouse: device is a pointer
    571. [   757.958] (II) config/udev: Adding input device PS/2+USB Mouse (/dev/input/mouse0)
    572. [   757.958] (II) No input driver specified, ignoring this device.
    573. [   757.958] (II) This device may have been added with another device file.
    574. [   757.960] (II) config/udev: Adding input device Logitech Lenovo USB Optical Mouse (/dev/input/event6)
    575. [   757.960] (**) Logitech Lenovo USB Optical Mouse: Applying InputClass "libinput pointer catchall"
    576. [   757.960] (II) Using input driver 'libinput' for 'Logitech Lenovo USB Optical Mouse'
    577. [   757.960] (**) Logitech Lenovo USB Optical Mouse: always reports core events
    578. [   757.960] (**) Option "Device" "/dev/input/event6"
    579. [   757.960] (**) Option "_source" "server/udev"
    580. [   758.021] (II) event6  - Logitech Lenovo USB Optical Mouse: is tagged by udev as: Mouse
    581. [   758.021] (II) event6  - Logitech Lenovo USB Optical Mouse: device set to 1000 DPI
    582. [   758.021] (II) event6  - Logitech Lenovo USB Optical Mouse: device is a pointer
    583. [   758.021] (II) event6  - Logitech Lenovo USB Optical Mouse: device removed
    584. [   758.056] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:02.0/usb2/2-4/2-4:1.0/0003:17EF:6019.0005/input/input9/event6"
    585. [   758.056] (II) XINPUT: Adding extended input device "Logitech Lenovo USB Optical Mouse" (type: MOUSE, id 13)
    586. [   758.057] (**) Option "AccelerationScheme" "none"
    587. [   758.057] (**) Logitech Lenovo USB Optical Mouse: (accel) selected scheme none/0
    588. [   758.057] (**) Logitech Lenovo USB Optical Mouse: (accel) acceleration factor: 2.000
    589. [   758.057] (**) Logitech Lenovo USB Optical Mouse: (accel) acceleration threshold: 4
    590. [   758.117] (II) event6  - Logitech Lenovo USB Optical Mouse: is tagged by udev as: Mouse
    591. [   758.117] (II) event6  - Logitech Lenovo USB Optical Mouse: device set to 1000 DPI
    592. [   758.117] (II) event6  - Logitech Lenovo USB Optical Mouse: device is a pointer
    593. [   758.118] (II) config/udev: Adding input device Logitech Lenovo USB Optical Mouse (/dev/input/mouse1)
    594. [   758.118] (II) No input driver specified, ignoring this device.
    595. [   758.118] (II) This device may have been added with another device file.
    596. [   758.119] (II) config/udev: Adding input device HDA NVidia Front Mic (/dev/input/event8)
    597. [   758.119] (II) No input driver specified, ignoring this device.
    598. [   758.119] (II) This device may have been added with another device file.
    599. [   758.120] (II) config/udev: Adding input device HDA NVidia Rear Mic (/dev/input/event9)
    600. [   758.120] (II) No input driver specified, ignoring this device.
    601. [   758.120] (II) This device may have been added with another device file.
    602. [   758.121] (II) config/udev: Adding input device HDA NVidia Line (/dev/input/event10)
    603. [   758.121] (II) No input driver specified, ignoring this device.
    604. [   758.121] (II) This device may have been added with another device file.
    605. [   758.122] (II) config/udev: Adding input device HDA NVidia Line Out Front (/dev/input/event11)
    606. [   758.122] (II) No input driver specified, ignoring this device.
    607. [   758.122] (II) This device may have been added with another device file.
    608. [   758.123] (II) config/udev: Adding input device HDA NVidia Line Out Surround (/dev/input/event12)
    609. [   758.123] (II) No input driver specified, ignoring this device.
    610. [   758.123] (II) This device may have been added with another device file.
    611. [   758.124] (II) config/udev: Adding input device HDA NVidia Line Out CLFE (/dev/input/event13)
    612. [   758.124] (II) No input driver specified, ignoring this device.
    613. [   758.124] (II) This device may have been added with another device file.
    614. [   758.125] (II) config/udev: Adding input device HDA NVidia Line Out Side (/dev/input/event14)
    615. [   758.125] (II) No input driver specified, ignoring this device.
    616. [   758.125] (II) This device may have been added with another device file.
    617. [   758.126] (II) config/udev: Adding input device HDA NVidia Front Headphone (/dev/input/event15)
    618. [   758.126] (II) No input driver specified, ignoring this device.
    619. [   758.126] (II) This device may have been added with another device file.
    620. [   774.066] (II) event1  - Power Button: device removed
    621. [   774.084] (II) event0  - Power Button: device removed
    622. [   774.096] (II) event2  -   USB Keyboard: device removed
    623. [   774.104] (II) event3  -   USB Keyboard: device removed
    624. [   774.116] (II) event7  - C-Media USB Audio Device   : device removed
    625. [   774.140] (II) event4  - Dell Dell USB Keyboard: device removed
    626. [   774.152] (II) event5  - PS/2+USB Mouse: device removed
    627. [   774.184] (II) event6  - Logitech Lenovo USB Optical Mouse: device removed
    628. [   774.213] (II) UnloadModule: "libinput"
    629. [   774.213] (II) UnloadModule: "libinput"
    630. [   774.213] (II) UnloadModule: "libinput"
    631. [   774.214] (II) UnloadModule: "libinput"
    632. [   774.214] (II) UnloadModule: "libinput"
    633. [   774.214] (II) UnloadModule: "libinput"
    634. [   774.214] (II) UnloadModule: "libinput"
    635. [   774.214] (II) UnloadModule: "libinput"
    636. [   774.238] (II) Server terminated successfully (0). Closing log file.
    637. frank@frank-ET1331G:~$
    638.
  13. nsaspook
    Aug 27, 2009
    5,165
    5,686
    The X log says the monitor(s) output resolution is
    That should be OK with the standard timings pulled from the monitor(s) EDID. Did you try the auto timing mode function on the misbehaving monitor.
  14. frank55
    Thread Starter Active Member
    Dec 6, 2013
    301
    10
    Thanks bro appreciate all you effort, rebooted and it returns to the 1600-900 max resolution it has the right screen but short on the edges both sides, and on the Display controls it on the auto, it doesn't let me change nothing,i guess i have to live with it,if i can't control under scan
  15. frank55
    Dec 6, 2013
    301
    10
    Hi
    nsaspoon ; I 've got it right now,on the monitor settings after some struggle it was presented to a mode like wide screen sign ,it was hard to see it because all controls are in a weird place that are not very well marked ,thanks
    Hi
  16. nsaspook
    Aug 27, 2009
    5,165
    5,686
    I expect beer.
  17. frank55
    Dec 6, 2013
    301
    10
    My good friend as soon i said it was working right the soon things went bad again
    i had it working on both displays with resolution 1280-1024 0.0HZ ,which 0.0HZ is weird since only resolutions under that show up on both displays with no other options and none work right even screw the graffics so much so i have to reboot,and the interesting thing is everytime i reboot it goes to a screen; ''see pics'' a log in with name and password witch i put in and it goes nowhere,then the only way i can go to my desktop is if i do Xubuntu GNU grub recovery mode,this Xubuntu 18.04 is giving me headaches with these 2 monitors
  18. frank55
    Dec 6, 2013
    301
    10
    Ok guys i went the hard way which was reinstalling Xubuntu 18.04 and now it is working right set both monitors 1280-1024 75hz and seems both are set right now,keep my fingers crossed.
  19. nsaspook
    Aug 27, 2009
    5,165
    5,686
    While it's working now you should learn the methods (edit the config text files) of setting up specific screen resolutions in the X11 system so it uses your setup instead of default and auto setting..
  20. frank55
    Dec 6, 2013
    301
    10
    Thanks nsaspoon but that's a too hard task for me,never could understand all that stuff,i like things ,ore like plug& play,if i can't figure out stuff i loose less time doing a fresh install, anyway here my $ inxi -Gxx
    frank@frank-ET1331G:~$ inxi -Gxx
    bus-ID: 02:00.0 chip-ID: 1002:71c1
    Resolution: 1280x1024@75.02hz, 1280x1024@60.02hz
    version: 2.1 Mesa 18.0.5 Direct Render: Yes
