Hi I'm relatively new to electronics. No degree or anything, and I am wanting to switch relays with an ESP8266 D1 mini. There are also many other GPIOs I want to use including 3 interrupt pins, so due to the limited number of GPIOs I want to introduce 2 multiplexing ICs in parallel. I have had success using the cd4051be (datasheet attached) in the past, plus its nice and cheap on ebay. rather than a clock it uses 3 GPIOs as 3 bits, (which I will be using in parallel to the two ICs) switching between the 8 multiplexed pins on each IC. This way all i need is 1 input and 4 outputs to be used to create 8 inputs and 8 outputs. My question is, are there any (cheap) through hole packages with the same switching configuration that will digitally hold an output high or low (or even PWM if possible) after switching to a different multiplexed output?
I realise there are plenty of I2C multiplexers out there that will do I2C PWM but I haven't found a through hole package that will do it.
Cheers for the help.
Graham.
Graham.
