Hi crutshow,Sounds like homework.
We don't do your homework for you here, we do homework help, so you have to show some effort in answering the question.
Then we can perhaps help with some suggestions.
Thank ericgibb,hi Nice1,
We are not saying that you cannot ask for Homework help, but using the correct Forum should improve your chances of getting the help you are requesting.
MOD Note:
First misconception: Homework is NOT given so that you will go out and get a solution from someone else.Hi crutshow,
Your reply is not helping in this area, even if it is homework, it is not bad to get it other source. Home work is given so that you will go and look out for solution from higher level people. So if you can contribute positively to it then you do rather than ur formal reply. Thanks
I took a plant physiology class in college as an elective and I'll never forget a question I got on a final: "Describe the role of water in plant life."Please What are the application of measurement and instrumentation in Electrical Engineering.
Thank you MrchipElectrical Engineering is a very wide field. Perhaps you can narrow it down a bit so that we can better help you.
What field are you interested in?
Power Generation
Nuclear Engineering
Power Transmission
Renewable Energy
Energy Storage Engineering
Automotive Engineering
Electric Automotive Engineering
Autonomous Vehicles
Industrial Plant Engineering
Aerospace Engineering
Avionics
Audio Electronics
RF Electronics
Consumer Electronics
Computer Electronics
Network Systems
Internet Of Things
Microelectronics
Medical Electronics
Solid-State Electronics
Nano Technology
Artificial Intelligence
Sorry, you have to choose ONE area.Thank you Mrchip
please I would like you to explain more on how it is applied in those areas, in either 4 or more areas. Thanks
Thank you haveI took a plant physiology class in college as an elective and I'll never forget a question I got on a final: "Describe the role of water in plant life."
It's one of those questions that seems impossibly broad and basic. Without having studied it and thought about it, there's no way you could write a 90-minute essay. Where do you begin? But, I had studied it and could recall the maybe 6 key points the professor had lectured about. So I started writing.
My point is, you should have already been lectured on, or assigned relevant readings on the topic and you should be able to start listing a few concepts.
Power Generation
Nuclear Engineering
Power Transmission
Renewable Energy
Autonomous Vehicles
Avionics
Audio Electronics
RF Electronics
Network Systems
Internet Of Things
Microelectronics
Medical Electronics
Nano Technology
Thanks for your concernSorry, you have to choose ONE area.
I have no training or knowledge in this area but I can imagine a few uses: Billing, in-the-field technical service, equipment testing, and plant operation monitoring. I’m sure you can think of more.How can it be apply in power transmission.
by Robert Keim
