Anyone has an idea for this Logic
jic222013
Joined Feb 26, 2014
1
Im using logic gates to do the logic then do the PLC
Let’s say I have 3 motors, Motor A, Motor B and Motor C “All could be online, offline”
If I turn-on Motor B first, it is going to be Primary motor.
And If I turn on Motor C next, it is going to be Secondary
And if I turn on Motor A, it should be Tertiary..
If Motor C turned off then Motor A should become Secondary and Motor C will be tertiary even if it is in OFF mode and so on …. I will have six scenarios
Motor A Motor B Motor C
Primary Secondary Tertiary
Primary Tertiary Secondary
Secondary Primary Tertiary
Secondary Tertiary Primary
Tertiary Primary Secondary
Tertiary Secondary Primary
GopherT
Joined Nov 23, 2012
8,009
Could you put some context around this? Like, why do you need this? Is the primary, secondary, tertiary lable for software or do you bed a complete solution in discrete logic chips for some reason.
A better explanation will get you an answer vs ignored.
28,686
what is the reason for (discrete?) logic gates, why not go directly to PLC?
Is this PLC as in Industrial definition or a μp?
