Any simulation software for circuits that can do multiple air core transformers?
zero_coke
Joined Apr 22, 2009
294
I need a circuit simulator which can get me the voltage and current at any point in a 4-coil transformer setup. So basically I have 4 coils which are linked to each other and they are all non-ideal air-core transformers. I need to get the voltage induced in each coil and the current running through them.
No one knows??
Anyone can help me on this?
zero_coke
Joined Apr 22, 2009
294
I don't know how to model it ...that's my issue. How can I model 2 set of transformers all together?
So i have: Coil #1 & Coil #2 --> Inductively coupled
Coil #2 & Coil #3 --> Resonant coupled
Coil #3 & Coil #4 --> Inductively coupled
I want to model this in some simulation software so that when I give it an input to coil #1 I want to know what I receive on coil #4 (and so on for coil #2 & coil #3 but mainly the load coil which is coil #4).
21,227
Ron beat me to it but in LTSpice a transformer is modeled as a pair of inductors with a defined coupling coefficient. Join the LTSpice Yahoo group and ask the wizards there how to do it. You'll be inundated with answers.
zero_coke
Joined Apr 22, 2009
294
Edit: This simulator is terrible...its so hard to use...is there a more intuitive one where you can just drag and drop components instead of having to type in stuff for every component?
zero_coke
Joined Apr 22, 2009
294
I like Multisim, it's very nice but I don't see any air-core transformers in the component library where I can specify the coupling coefficients and mutual inductances....darn it!
zero_coke
Joined Apr 22, 2009
294
you saved me once again Brownout, thanks ! I had Multisim v11 installed and it doesn't have these components in the library.
