I have read through the AAC articles on how Op Amps are used, and have spent hours reading other articles and watching tutorial videos. For some reason my marginally dyslexic brain struggles with what should be very simple logic.
I am building a low-noise battery-powered (portable) audio mixer around a few NE5534s. The power is supplied by a pair of PP3 batteries providing me with +-9v and 0v.
My starting point is this design (below) from here http://www.eeweb.com/blog/extreme_circuits/balanced-microphone-preamplifier
I am using starting from this point because I was advised that it is a good design with low noise and a limited number of components.
Input is balanced. R3 is in place to avoid input oscillation. P1 serves to match the feedback loops. Gain is set at 50dB
I have not found any other circuits which use a feedback loop on both the inverting and noninverting inputs of the opamp at the same time, which makes cross referencing difficult.
My confusion this morning:
1) with most opamp designs, the noninverting pin of the opamp is not connected to the output (via R6) when an inverting feedback loop is being used.
2) I was advised that to use this circuit for an unbalanced input, R1 would be connected to Common Ground rather than Pin2 of K1... My interpretation of this is the following:
This confuses me because both inputs of the opamp are connected to the same signal. Both inverting and noninverting inputs have feedback loops, meaning that both inputs on the opamp are connected both to the signal, the output and the common ground (which in this case is just the chassis ring of the 1/4" output). (NOTE: in the above I have set the gain to 0)
QUESTION assuming that my interpretation is wrong:
a) should R12 be connected to the 0v rather than the input, and the chassis rings be connected to each other?
b) Should R36 be 200k and the connection between R36-C7 be a 20k resistor?
If someone can lend me a hand I would be most grateful.
