AND GAte problem
Hassaan Aslam
Joined Apr 20, 2013
11
hi!!! i am a beginner, when i use and gate i get '1' output even if my inputs are '0'. i have tried two ic's 7408 and 4081 but i am getting same problem with both of them. can any one guide me hoe to use these ic's correctly.... :confused: :( :confused:
DerStrom8
Joined Feb 20, 2011
2,390
Another question is what are you using for power? The 7408 is only designed for 5 volts on Vcc. If you connected a higher voltage, you've likely damaged the chip.
Also, what are you using to drive the inputs?
kubeek
Joined Sep 20, 2005
5,795
You need to have ALL inputs connected to either supply voltage or ground or output of another gate. Without that the inputs will act like antenna and will have any value.
kubeek
Joined Sep 20, 2005
5,795
You connect them to either ground of supply voltage. You can also connect them through a resistor to ground, for example 10k.
