Yes. What would the DC level be?So if 1.1V=1100mV pp that means it would have a maximum amplitude at 550mV and a minimum amplitude at -550mV.
That's correct. So, your output would swing from (23.9 + .55) to (23.9 -.55), right?The DC level would be 23.9V
That's right. In fact, with a 741 (and many other op amps), the limiting voltage will be substantially below the supply voltage.No. It would be limited to 9V
That is either a trick problem, or a very poorly designed one.
This is apparently homework. Are you saying that you have not covered AC analysis of RC networks in class?This would be the graph not taking the capacitor into consideration. What effect does the capacitor have?
That is wrong.The last opamp is forced against the upper limit by the non-inverting gain on the 1 volt input at the positive input.
The sine wave will cause the output to swing down from the upper limit as the gain of -10 for this side causes the opamp to un saturate.
Remember also that a 741 can not swing up to the upper rail voltage of 9 volts because of the output stage limitation. This case about 7 volts.
[soapbox]Where are you a student? Who is paying for your education? If anyone is, they are being ripped off, IMHO. Teachers are supposed to teach, not just tell you what to learn. Learning to do research is a necessary skill, but this is fundamental stuff. It should be explained to you in an interactive environment.[/soapbox]No we have not. We are expected to learn everything ourselves.
Thread starter | Similar threads | Forum | Replies | Date |
K | Analyzing Output [ SOLVED ] | Programming & Languages | 24 | |
R | Need a help with analyzing a TTL logic circuit | Homework Help | 21 | |
O | Analyzing a PCB circuit for measuring plasma cutter voltage | General Electronics Chat | 6 | |
W | analyzing a very simple circuit | General Electronics Chat | 2 | |
L | analyzing schematic diagram | Digital Design | 5 |
by Aaron Carman
by Jake Hertz
by Aaron Carman
