some point they need to
Thanks for reply?Ideally you have a split ground plane with the analog ground part under the analog parts and the digital ground under the digital parts.
The grounds are then joined together at just one point under or near the A/D converter.
In my past job I was given a mixed signal PCB, to determine why the A/D converter digital word output had excessive noise.
Examination of the board showed that the board layout designer had misconnected the analog and digital ground pins of the A/D converter to the analog and digital ground planes .
Redoing the board with the correct ground connections solved the problem.
Anytime the analog and digital grounds have more than one common connection, you have a ground loop, with some of the digital ground currents going through the analog ground, causing analog ground-bounce noiseCould you share a bad connection example?
https://www.analog.com/media/en/training-seminars/tutorials/MT-031.pdfCan someone clarify the point of connection for me. Why join grounds near the ADC?
I’d thought that all connections to ground on the ADC should have a capacitor to the associated power supply, at the chip. And where I’m confused is I’d connect the various grounds near their associated power supplies, not at the chip.
Depends upon how much voltage difference the ADC can tolerate between the analog and digital grounds (ADS1158 value below).Can someone clarify the point of connection for me. Why join grounds near the ADC?
Nsa's linked document shows the following image:Depends upon how much voltage difference the ADC can tolerate between the analog and digital grounds (ADS1158 value below).
If the ground voltage difference due to the various ground resistances and the two supply currents exceeds that value (0.3V in this case for the digital ground lower than the analog ground), it would be a problem.
Connecting the two grounds at the ADC eliminates that possible problem.
Right.Question, if I were to connect both grounds as close as possible to the ADC, would the use of resistors and ferrites in series still be recommended?
EDIT: I just realized I asked a stupid question... those RL symbols are there to represent the resistance and inductance of the traces, and are not actual components, right?
