ampere of pico fuse
minh
Joined Nov 24, 2010
41
Dear all..
By accident (short circuit) the pico fuse(dimension like as resistor 1 watt) of my wattmeter is blown . Could you help me to know value of ampere (ie: 250v 1/4 amp...) this pico fuse. the color code in photo please. In the time waiting your help can I used glass fuse for replace .Thank you so much
minh
Joined Nov 24, 2010
41
First Thank you to all for the time help me
Yes I am not sure it is pico fuse. But when cut ( cross-sectional) I seen outside paint + code color next metal???
and inside is white ceramic ̣??? ̣don't seen nothing magnet wire.
I tried replace with 100 ohm 1 watt but quickly too hot.
Next I replace with fuse glass 1/4 ampere is working (but not sure is alright.
bertus
Joined Apr 5, 2008
22,278
Do you have a schematic where this device is used?
The value can be 6.8 or even 0.68 Ohms.
We do not know the original color of the black ring.
Markd77
Joined Sep 7, 2009
2,806
How hot is too hot?
Often 1W resistors will get very warm but still be working as intended. The reason is that the designer thought a 1/4 W would be destroyed. Even with 1/2 W dissipated by a 1W resistor it will be too hot to touch.
