Speed is 3.4GHz. No overclocking!!. No heavy loading.Hello,
What is the speed used now?
No. I didn't assemble pc myself. Last week for the first time I was trying to overclock my cpu and I noticed this high temperature issue. Actually few months back I had problem with my ATX supply. At that time, while replacing my ATX as a curious exercise I dismantled my CPU from chassis and did some cleaning and put it back without thermal paste(That was really lame!!). Last week while reading something on overclocking I came to know about thermal paste then I immediately did the correcting action, applied thermal paste. FYI without thermal paste my cpu temp was reaching over 80C. Now it goes to above level. What is the exact issue??? Do I need to use another better quality thermal paste?Hello,
Did you assemble the PC yourself?
If so did you use thermal grease between the CPU and cooler?
I really don't know how to check that 'dust' issue. On the exterior it looks fine. And in case if it is full of dust how can I clean it up?? I can always try cleaning. By the ways that's what cause this mess-Cleaning the highly efficient thermal grease and running processor for this long without it. Fortunately my processor didn't fry.Hello,
Are the cooler and fan free of dust?
Dust can give a low performance of the cooler and fan.
Are the case fans free of dust also?
Generally around 26/27C. But that may not be an issue.You know, i just noticed you reside in India.
What is the air temp in the room w/ the PC?
Here is the link.Hello,
I can not find the mentioned motherboard on the asus site.
Are you sure of the numbers?
Phenom IIX4 965 (HDZ965FBK4DGI),3.4GHz,140W,rev.C2,SocketAM3,Quad-Core ALL
1003
Phenom IIX4 965 (HDZ965FBK4DGM),3.4GHz,125W,rev.C3,SocketAM3,Quad-Core ALL
1003
I suppose C3 because with HW monitor my processor power dissipation goes around 117-118WHello,
Wich version of the phenom chip do you have?
The C2 version (140 Watt) will create more heat as the C3 version (125 Watt).Rich (BB code):Phenom IIX4 965 (HDZ965FBK4DGI),3.4GHz,140W,rev.C2,SocketAM3,Quad-Core ALL 1003 Phenom IIX4 965 (HDZ965FBK4DGM),3.4GHz,125W,rev.C3,SocketAM3,Quad-Core ALL 1003
The chip is supported from bios version 1003 and up.
See this page for more info:
http://www.asus.com/Motherboards/AMD_AM3/M4A88TDM/
Under the tab download you will find drivers and manuals.
I had this problem with my overheating AMD processor, it would run for 5 minutes then crash Windows. I took out the heatsink and it was completely clogged with dust. I used a paint brush to get out the dust and it was then fine.Hello,
