I am building a big passive AM loop antenna. 42x29", 17 turns of 24 ga CCA twisted wire, 1/4" spacing, feedpoint at the bottom so it is horizontally polarized. it measured 637 uH so I used the 14-125 pF variable capacitor in series. inductively coupled to the radio with a loose wire in series with the antenna, 7 turns wrapped around the radio.
it's not receiving stations very well and the VR has little to no effect. the antenna is about useless.
however, when I tune the radio to 1400 KHz and adjust the VR, it brings in 550 KHz. (very strong local station) double checked everything (antenna only, induction wire detached) and got L= 636 uH, C= 106 pF.
with those the resonance frequency should be 612 KHz, but maybe my LCR meter is a little off, there is capacitance between the turns, the inductive coupling loop adds L, etc. it's in the neighborhood of 550.
then I tuned the radio to 1395 and adjusting VR wouldn't bring in anything.
so why does the radio receive 550 when tuned to 1400?
