Hi fellas!!
Im into Airsoft and one major thing thats missing in the majority of the weapons
out there is a bolt stop when the mag is out of ammo.
in an electric fully automatic airsoft-rifle the gearbox has a notch in one of the
gears that can be used to push a microswitch at every rotation.
i wanna use that to create a circuit in a small form factor that has 2 functions,
one function is to count to 50 rotations of that specific gear
through a microswitch
and when that circuit has reached 50 it will break another closed circuit so that
the gun stops firing.
After that when another microswitch is pressed the counter is zeroed and will start
counting again the next time i start to fire.
i know it sounds messy, i have tried searching around but since i have very little
knowlage of terms and names i have no luck searching.
im not looking for you guys to give me a complete diagram but could you point
in the right direction at least?
the gun atm has a battery, a motor, and mosfet circuit that acts as the on/off-switch,
from the mosfet circuit i have 2 wires from the trigger pins on the transistor to the weapons
trigger-microswitch, and that's the circuit i figured i want to break at 50, so there's no
high voltage or high amp that need to be handeled since it's only the trigger-wires to the
mosfet..
take care guys and pardon my english, cant be good at everything lol.
mosfet..
