This is kind of a worrisome event...but is most certainly pilot error.
Cheers, DPW [Everything has limitations...and I hate limitations.]
They hit the side of a solid rock mountain.I have been looking at all the pics I can find, but I can not see an impact crater.
I assume the large blacken area was due to fuel fire.
But there still should be an impact zone.
There was in Pennsylvania.
No, the solid rock mountain they hit was already black.I assume the large blacken area was due to fuel fire.
The biggest problem with this is the premise -- IF you are maneuvering your aircraft by a compass.... Virtually no aerial navigation is done by compass even if light aircraft. You use a directional gyro. For cross country navigation you use radio navaids or GPS. Large aircraft also use inertial guidance systems (don't know how prevalent that still is). The mag compass is a back up (to a back up, these days).This is kind of a worrisome event...Airbus deviated from its course for no apparent reason when in the vicinity of the CERN collider (worlds strongest magnetic field.) If you are manoevering your aircraft by a compass bearing and a strong magnetic field is nearby...you're in trouble! The CERN Collider does not even have to be ON, as even the residual magnetic field would be intense!
ps: I had to remove the ICOM speakers from my boat as the large magnets contained there-in affected my compass adversely.
Why not? One of the most common conclusions for the cause of crashes is "controlled flight into terrain".https://www.flickr.com/photos/ministere_interieur/16924817002/in/photostream/
Straight into the side of a mountain. Hard to believe the pilots were in control of the plane.
Where are you getting this claim? As near as I can find, the field strength at CERN is in the 11T to 14T range. The magnets I worked with at NIST, Boulder back in the late 1980's were 12T and the magnets at MIT that we used from time to time were 27T. The record is currently in the 95T range.This is kind of a worrisome event...Airbus deviated from its course for no apparent reason when in the vicinity of the CERN collider (worlds strongest magnetic field.)
No storms, just normal cover from what I've read.Why not? One of the most common conclusions for the cause of crashes is "controlled flight into terrain".
Have they said what the weather was like at the time?
Contacting ATC would have been third on the list. Aviate, Navigate, Communicate. In THAT order!No storms, just normal cover from what I've read.
If they 'had' or 'chose' to descend you would think they would contact the ATC or someone.
Unlawful interference, maybe.
True, but it was a very long time before they hit that mountain after the start of the descent.Contacting ATC would have been third on the list. Aviate, Navigate, Communicate. In THAT order!
If true (the NYT is normally a credible source) I just don't know what to think about what happened.PARIS — As officials struggled Wednesday to explain why a jet with 150 people on board crashed in relatively clear skies, an investigator said evidence from a cockpit voice recorder indicated one pilot left the cockpit before the plane’s descent and was unable to get back in.
