Ad622ar
38,515
If you read the data sheet on page 7, it states the output voltage is referenced to the REF pin potential (i.e. for 0V output the voltage between the output and REF is 0V). Thus for normal operation with a plus and minus supply, you connect the REF pin to circuit common.
Edit: If you connect REF pin so some voltage, then the output will referenced to (offset by) that voltage.
