I would like to build some sort of circuit so that it will pass freqs < 80hz at normal volume, and cut out freqs (-30db atleast) > 300hz. What kind of circuit would I use to achieve this? Low pass or high cut? What is the difference between the two? And would you suggest that I make it an active or passive (rc) filter?
