Hi All,
I decided to built an astable oscillator on 555 basis. Required frequency is 1050 Hz, (in other experiment it will be 2050 Hz). Ambient temperature varies from 0 to +40 ° C.
Power supply from voltage regulator LM7812. The datasheet shows 12V at output with line regulation accuracy of 120mV , and load regulation accuracy of 240mV.
Timing capacitor will be polystyrene type, 0,1uF, with TC of 80 ppm and timing resistors with TC of 50 ppm.
Is it real to obtain frequency with drift of 1 % or better with those components?
