I suspect what you have is a "universal" AC/DC motor. They are not synchronous, so changing the line frequency will not change the speed, except as it might affect power or efficiency. Check out "universal motor" on Wikipedia.
The phase controls that you mention (diac, triac, scr) are to slow the motor (edit:delete this, not speed it up). Basically, you reduce the power supply, so the motor slows down. Unloaded, they usually have very high speed. In fact, some will self destruct, if operated completely unloaded. For low power, some people just use a light dimmer.
Another way to slow it down is with a transformer or Variac.
John
John
