A stud finder relies on magnetic detection of nails or gyproc screws etc, there is also a capacitive version that detect a change in density (stud).I have a stud finder (used to locate studs inside a wall) that indicates when AC voltage is present. It doesn't appear to
require that the circuit be loaded. They're sold in most all home improvement and hardware stores.
Yes, a simple stud finder works as you describe. The multi-tool version is both a stud finder and mains power indicator. The reason it is important, is to make sure the user does not drill, screw or pound through a live wire.A stud finder relies on magnetic detection of nails or gyproc screws etc, there is also a capacitive version that detect a change in density (stud).
Max.
