Can you tell more about what you want to do. And what kind of voltages/current magnitude we are talking about. Another important parameter is the bandwidth(speed) of your signalHi,
I am wondering if a AC-AC opto-isolator actually exist?
I know that a transformer is a good example, but what about dual in-line package IC chip? Thank you!
Remove the resistors in the primary.when i use this method, the current thru the transformer is too small to detect any voltage on the primary side, let alone the secondary side.
Is the Load a voltage divider?i am trying to step up the voltage so that i can voltage divide the secondary voltage to replicate the Vout across the inverter Load resistance.
Nope. The load is drawing most of the current. The voltage divider is just to draw as little current as possible but still be able to produce a voltage from the transformer to sense.Remove the resistors in the primary.
I cannot remove the resistors as the Vout will experience a loading directly from the transformer and the voltage level of Vout will drop. Thus giving a misrepresentation of the actual output voltage of the inverter.
A transformer of the proper characteristics should work fine for your requirement. The magnetizing current is very small as long as it is operating at or above its design frequency and voltage. You should not have to place any resistor divider in series with a transformer of the correct design...................
I realise that the current through the transformer is too low to "drive" the transformer. Thus, making the transformer unable to sense the voltage.
Well, they shouldn't be in there. You'll need to solve that problem another way, such as ensuring the transformer is properly rated for the input voltage and frequency.I cannot remove the resistors as the Vout will experience a loading directly from the transformer and the voltage level of Vout will drop. Thus giving a misrepresentation of the actual output voltage of the inverter.
That should work also, but be aware that both sides require a separate, isolated power supply voltage. So you will need to generate a DC voltage from your output to power the isolator.i was searching and found an isolation amplifier.
not sure if this could work? comments please thanks!
