Hello there
I'm doing an Online Electrical Engineering course and we're up to the last component of the course. We're currently doing Asymmetrical 3 phase, because it's online we haven't had much practice with these maths concepts compared to say university.
Here are the questions with my answers:
1. In a 3 phase circuit with resistance earthed and neutral and earth fault in phase “A” which produces a fault current of 800 amps.
Load currents may be taken as zero.
What will be the positive, negative and zero sequence currents in this system?
Answer
I have Ia = 800 for Phase A, Ib = 0 and Ic = 0 and I assume this is a Phase-to-earth fault
According to this source https://www.selinc.com/WorkArea/DownloadAsset.aspx?id=100688, when Phase B and Phase C is zero (as suggested by "Load currents may be taken as zero"): the zero,
positive and negative sequence are all 1/3Ia.
Therefore Ia = 800A and I0, I1, I2 = 267A. Is this right?
2. In a three phase 4 wire system with phase to neutral voltage of 230V, a balanced set of resistive loads of 8 ohms are connected between each phase and neutral.
If the fuse cartridge of phase “C” blows, what will be the currents in the corresponding phases and the symmetrical components of the load currents?
Answer
Because it's a 4 wire system with a neutral, the voltage difference through the resistors will utilize the phase to neutral voltage, and since they're both 8 ohms, the current magnitude will be the same.
Therefore |Ia| = |Ib| = V/R = 230/8 = 28.75 Amps
I turned Phase A and Phase B into their phasor values respectively to:
Ia = 28.75 arg(0)
Ib = 28.75 arg(240)
and because C is blown:
Ic = 0
I've calculated the Asymmetrical components using a calculator (under 012 Polar):
The printscreen is here:
I think Neutral current flows by adding Ia + Ib utilizing Kirchoff's current law, this equates to 28.75 arg(60), but I doubt I use this in my phase diagram.
Is this the right answer/approach?
3. In the circuit above in problem 2, if there is no neutral wire used and Line to Line voltage of 400Volts is given, and connected in Star configuration
Note (only 3 wire system now).
Please note: (This is the known condition, when a motor is subjected to loss of a phase. Which is also known as “single-phasing or poling”).
Answer
Because there is no neutral, the potential difference is 400V, and the star load becomes a series resistance of 8+8 = 16 ohms as Phase C is gone. The current is 400/16 = 25 amps.
Using Kirchhoff's voltage law, we can find the individual voltage drops of each resistor: 25*8 = 200V for both Ia and Ib resistors: this is consistent with the content in the bottom of http://www.allaboutcircuits.com/vol_2/chpt_10/5.html
I don't know the angle direction for each however, and I'm assuming Ic is = 0 because it's blown to begin with. I've been told it's 180degrees apart between Ia and Ib, but don't know how I can see it? anyone to clarify?
I'd really appreciate the feedback, I don't have a strong theoretical Elec Eng background compared to people who has been to University haha
Cheers!
Answer
Answer
Ia = 28.75 arg(0)
Ib = 28.75 arg(240)
Ic = 0
Answer
Cheers!
