Anybody with experience with reading tiny amounts of EMF an inch away the contacts of an electromechanical timer as it switches internally? If I can do "before & after" measurements putting properly grounded barriers & shielded wiring it could helpful. That way I can see how much each step helps & if the only solution is to move an Arduino I2C LCD a tiny bit farther away from the 200 terminal washing machine electromechanical timer.
Will the following Gauss Metera or similar AC EMF Gauss have that ability?
https://www.amazon.com/Gauss-Magnetic-Field-2000mG-Meter/dp/B00MNEFCI6/ref=cm_wl_huc_item
https://www.amazon.com/KKmoon-Handheld-Electromagnetic-Radiation-Dosimeter/dp/B073W7MPNN
