I just finished making an art piece and after I made this video, the circuit stopped pulsing after a few seconds of being on. The video is here:
http://youtu.be/5wIhyV-lBzA
As you can see, it's a wire sculpture with a electronic circuit inside. I tried resoldering the connection points and it worked, until I tried to put it together again and the whole thing went dead. So now, I'm trying to replicate the circuit, but I'm having trouble with the duty cycles. In the video, the duty cycles are about 50% and high and low are about approx a little more than 1 second each. However, I replicated the circuit exactly (quadruple checked the connections), and the duty cycle seems to by a lot higher, with a high of 1 second and low of maybe 0.1 or 0.2. Why might this be?
This is the circuit I used:
I actually used a BC478 and instead of the 33k, I used a 10k pot and added a switch. Everything else is as the schematic reads.
I saw Bill's throbbing LED circuit and plan on trying to make the first one with the 50% duty cycle. What should the resisters be to get about 1 second of high/low time?
Also, don't know if this is possible, but could a capacitive on/off switch we added to the circuit so that by touching the wire sculpture the piece would turn on and off? Thanks for your help and contribution to modern art!
